소개
This is likely the simplest repair possible for this device. Simply access the shaft lock pin after opening the case.
필요한 것
Start by removing the housing cap by unscrewing it.
Next, unscrew the now exposed collet nut while holding down the shaft lock button.
If the shaft lock pin is not engaging the rotary gear, or if the spring is missing or damaged, it will need to be replaced.
Remove the damaged shaft lock pin and spring by hand.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
These instructions are idiotic! I want to replace the shaft lock pin because it is not WORKING. Step 1 instructs me to use the shaft lock pin to remove the exposed collet nut. The reason I am changing the shaft lock pin is because it won’t hold the shaft for loosening the collet nut. DUH!
mitchthane - 답글
three years later and I came to the same conclusion: DUH
