주요 콘텐츠로 건너뛰기
Dremel MultiPro 395 Armature Replacement
필요한 것
  1. Dremel MultiPro 395 Armature Replacement, Remove the Blue caps: 1 단계, 이미지 2개 중 1개 Dremel MultiPro 395 Armature Replacement, Remove the Blue caps: 1 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove the blue caps located on either side of the MultiPro, using a 3 mm flathead screwdriver.
  2. Dremel MultiPro 395 Armature Replacement, Remove the carbon brushes: 2 단계, 이미지 2개 중 1개 Dremel MultiPro 395 Armature Replacement, Remove the carbon brushes: 2 단계, 이미지 2개 중 2개
    • Carefully remove the carbon brushes attached at the end of the springs by gently pulling on the springs using your hands.
  3. Dremel MultiPro 395 Armature Replacement, Removing the Hanger: 3 단계, 이미지 2개 중 1개 Dremel MultiPro 395 Armature Replacement, Removing the Hanger: 3 단계, 이미지 2개 중 2개
    • Pull one side of the hanger up and then pull away from the Multipro until the other side can be pulled out.
  4. Dremel MultiPro 395 Armature Replacement, Remove the screws in the casing: 4 단계, 이미지 3개 중 1개 Dremel MultiPro 395 Armature Replacement, Remove the screws in the casing: 4 단계, 이미지 3개 중 2개 Dremel MultiPro 395 Armature Replacement, Remove the screws in the casing: 4 단계, 이미지 3개 중 3개
    • Remove the 4 screws located on the bottom of the Multipro with a T15 screwdriver.
  5. Dremel MultiPro 395 Armature Replacement, Removing the chuck cap: 5 단계, 이미지 3개 중 1개 Dremel MultiPro 395 Armature Replacement, Removing the chuck cap: 5 단계, 이미지 3개 중 2개 Dremel MultiPro 395 Armature Replacement, Removing the chuck cap: 5 단계, 이미지 3개 중 3개
    • Hold down the collet lock, remove the chuck cap from the top of the Multipro by screwing counterclockwise.
  6. Dremel MultiPro 395 Armature Replacement, Removing the black housing cap: 6 단계, 이미지 3개 중 1개 Dremel MultiPro 395 Armature Replacement, Removing the black housing cap: 6 단계, 이미지 3개 중 2개 Dremel MultiPro 395 Armature Replacement, Removing the black housing cap: 6 단계, 이미지 3개 중 3개
    • Remove the black housing cap from the Multipro located directly below the chuck cap.
  7. Dremel MultiPro 395 Armature Replacement, Removing the outer casing: 7 단계, 이미지 3개 중 1개 Dremel MultiPro 395 Armature Replacement, Removing the outer casing: 7 단계, 이미지 3개 중 2개 Dremel MultiPro 395 Armature Replacement, Removing the outer casing: 7 단계, 이미지 3개 중 3개
    • Pull the bottom side of the casing up to remove it.
  8. Dremel MultiPro 395 Armature Replacement, Removing the motorshaft: 8 단계, 이미지 3개 중 1개 Dremel MultiPro 395 Armature Replacement, Removing the motorshaft: 8 단계, 이미지 3개 중 2개 Dremel MultiPro 395 Armature Replacement, Removing the motorshaft: 8 단계, 이미지 3개 중 3개
    • Gently lift the motor shaft out of the Multipro.
  9. Dremel MultiPro 395 Armature Replacement, Removing the rubber ring: 9 단계, 이미지 3개 중 1개 Dremel MultiPro 395 Armature Replacement, Removing the rubber ring: 9 단계, 이미지 3개 중 2개 Dremel MultiPro 395 Armature Replacement, Removing the rubber ring: 9 단계, 이미지 3개 중 3개
    • Remove the rubber ring from the bottom of the armature.
  10. Dremel MultiPro 395 Armature Replacement, Removing the on/off switch: 10 단계, 이미지 3개 중 1개 Dremel MultiPro 395 Armature Replacement, Removing the on/off switch: 10 단계, 이미지 3개 중 2개 Dremel MultiPro 395 Armature Replacement, Removing the on/off switch: 10 단계, 이미지 3개 중 3개
    • Pull the on/off switch off of the 120V field, paying careful attention to the prongs on the on/off switch.
    • For reassembly, make sure the prongs are touching the metal connectors on the bottom of the 120V field
  11. Dremel MultiPro 395 Armature Replacement, Removing the armature: 11 단계, 이미지 3개 중 1개 Dremel MultiPro 395 Armature Replacement, Removing the armature: 11 단계, 이미지 3개 중 2개 Dremel MultiPro 395 Armature Replacement, Removing the armature: 11 단계, 이미지 3개 중 3개
    • Carefully slide the armature out of the 120V field.
  12. Dremel MultiPro 395 Armature Replacement, Inserting new armature: 12 단계, 이미지 3개 중 1개 Dremel MultiPro 395 Armature Replacement, Inserting new armature: 12 단계, 이미지 3개 중 2개 Dremel MultiPro 395 Armature Replacement, Inserting new armature: 12 단계, 이미지 3개 중 3개
    • Carefully slide the new armature back into the 120V field.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Cheyenne
회원 가입일: 09/17/14
292 평판
안내서 1개를 작성함
7가이드 댓글
This part does not seem to be my problem the only thing I have left on the shaft is the copper coil the fan and whatever the part above the fan it spins freely around and it seems to be set on a device that allows it to tilt. I am struggling with this, please point me in the right direction of the removal of the copper core coil.... There has got to be an easier way to remove this.
Johnny Reb - 답글
You dont remove the armature coil, you replace the entire rotating armature assembly...why are you trying to take the coil off?!?
Tracy Bueller -
The article does not mention why an armature needs to be replaced. So why is it necessary to replace an armature? If there is no obviously visible problem, what could be wrong with it?
mycle85719 - 답글
Failed front bearing. I have a 398 and the front bearing gets bathed in whatever youre cutting ... Like drywall dust, plaster, stone dust. And you cant just pull the collet mount off and replace the bearing, so you have to replace the whole armature (great design, dremel!). The good news is youll have fresh bearings and commutator (which should help the brush whine some). Youll also have a spare armature to carefully cut the collet shaft off of (hopefully in a way you can remount it...remember to rebalance the armature afterwards), then use a gear puller to take the front bearing off, and replace it with a better, more shielded one. Then youll have a replacement armature for when the first replacement front bearing jams up!
There could also be a broken fan, bent shaft, an electrical issue inside the windings...lots of reasons to need to replace the armature. Its just stupid you cant take the freaking front bearing off and have to replace the whole %#*@ assembly....
Tracy Bueller -
very good article, congratulations for the content
<a href="https://comodemorarpragozar.com/"> comodemorarpragozar </a>
tiagoraro - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 46
전체 시간: 8,884
