주요 콘텐츠로 건너뛰기
Dress Shirt Button Replacement
필요한 것
  1. Dress Shirt Button Replacement, Button: 1 단계, 이미지 1/2 Dress Shirt Button Replacement, Button: 1 단계, 이미지 2/2
    • Measure out two feet of thread and cut it.
  2. Dress Shirt Button Replacement: 2 단계, 이미지 1/3 Dress Shirt Button Replacement: 2 단계, 이미지 2/3 Dress Shirt Button Replacement: 2 단계, 이미지 3/3
    • The needle is sharp. Be careful when working.
    • Put the thread through the eye of the needle.
    • Pull the thread through so that both ends are even.
    • Tie both strings into a knot, closing the loop
  3. Dress Shirt Button Replacement: 3 단계, 이미지 1/2 Dress Shirt Button Replacement: 3 단계, 이미지 2/2
    • Begin sewing by putting the needle through the back of the fabric, out to the front, and through a hole in the button.
    • Make sure the button is facing the correct direction.
  4. Dress Shirt Button Replacement: 4 단계, 이미지 1/3 Dress Shirt Button Replacement: 4 단계, 이미지 2/3 Dress Shirt Button Replacement: 4 단계, 이미지 3/3
    • Put the needle through the hole diagonal and feed through to the back of the shirt
    • Repeat this process for the other diagonal.
    • Repeat the process of sewing through the diagonals multiple times.
  5. Dress Shirt Button Replacement: 5 단계, 이미지 1/1
    • When there is about 4 inches of thread yet, push the thread so that it is on the back side of the fabric.
    • Then push the needle back through making sure to not go through the button again.
  6. Dress Shirt Button Replacement: 6 단계, 이미지 1/3 Dress Shirt Button Replacement: 6 단계, 이미지 2/3 Dress Shirt Button Replacement: 6 단계, 이미지 3/3
    • Wrap the thread around the button 4-6 times.
  7. Dress Shirt Button Replacement: 7 단계, 이미지 1/3 Dress Shirt Button Replacement: 7 단계, 이미지 2/3 Dress Shirt Button Replacement: 7 단계, 이미지 3/3
    • Push the thread back through to the back side of the fabric.
    • Tie the knot off and cut.
결론
Your shirt is now ready to be worn again.
다른 한 분이 해당 안내서를 완성하였습니다.
Jonathan Wong
회원 가입일: 04/09/15
198 평판
안내서 1개 작성함
Cal Poly, Team 28-4, Green Spring 2015 Cal Poly, Team 28-4, Green Spring 2015 회원
CPSU-GREEN-S15S28G4
6 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 3,763
