주요 콘텐츠로 건너뛰기
Dresser Drawer Guide Tracks Replacement
필요한 것
  1. Dresser Drawer Guide Tracks Replacement, Broken Guide Tracks for a Dresser Drawer: 1 단계, 이미지 2개 중 1개 Dresser Drawer Guide Tracks Replacement, Broken Guide Tracks for a Dresser Drawer: 1 단계, 이미지 2개 중 2개
    • As you can see, the guide tracks that set the drawer in place are no longer attached to the dresser in the correct position.
  2. Dresser Drawer Guide Tracks Replacement: 2 단계, 이미지 1개 중 1개
    • You will need super glue and a staple gun because the dresser and the tracks are wooden. You can also use screws and a screwdriver if you would like.
  3. Dresser Drawer Guide Tracks Replacement: 3 단계, 이미지 1개 중 1개
    • Apply the glue to both sides on the wooden tracks. You will only need a small amount.
  4. Dresser Drawer Guide Tracks Replacement: 4 단계, 이미지 2개 중 1개 Dresser Drawer Guide Tracks Replacement: 4 단계, 이미지 2개 중 2개
    • Now you will want to place the tracks in the desired location inside the dresser. You will want to apply pressure from the top of the track to secure the clue to the wood. Let this dry for about 5-10 minutes.
  5. Dresser Drawer Guide Tracks Replacement: 5 단계, 이미지 2개 중 1개 Dresser Drawer Guide Tracks Replacement: 5 단계, 이미지 2개 중 2개
    • Once your clue has dried, you can now use the staple gun to ensure that the track is secure.
  6. Dresser Drawer Guide Tracks Replacement: 6 단계, 이미지 2개 중 1개 Dresser Drawer Guide Tracks Replacement: 6 단계, 이미지 2개 중 2개
    • Finally, once the tracks have been set and are secure, you can align your drawer to the tracks and slide the drawer back into the dresser.
결승점
작성자
2다른 기여자 명과 함께
jackson feld
회원 가입일: 10/29/19
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 56
전체 시간: 3,742
