주요 콘텐츠로 건너뛰기
Drift HD 720 LCD Screen Replacement
필요한 것
  1. Drift HD 720 LCD Screen Replacement, Battery: 1 단계, 이미지 1/2 Drift HD 720 LCD Screen Replacement, Battery: 1 단계, 이미지 2/2
    • Unscrew the back plate counterclockwise until it comes off.
  2. Drift HD 720 LCD Screen Replacement: 2 단계, 이미지 1/1
    • Push the black battery tab next to the battery to get the battery out.
    • Remove the battery.
  3. Drift HD 720 LCD Screen Replacement, LCD Screen: 3 단계, 이미지 1/1
    • Remove six 8mm long Philips head screws with the J0 Philips head from the outer case.
  4. Drift HD 720 LCD Screen Replacement: 4 단계, 이미지 1/1
    • Remove the back case from camera body.
  5. Drift HD 720 LCD Screen Replacement: 5 단계, 이미지 1/1
    • Carefully remove the battery housing from the camera body.
  6. Drift HD 720 LCD Screen Replacement: 6 단계, 이미지 1/1
    • Use J0 Phillips head to remove two 6mm long Phillips head screws from the motherboard.
  7. Drift HD 720 LCD Screen Replacement: 7 단계, 이미지 1/1
    • Remove the motherboard (green) from the front case housing.
  8. Drift HD 720 LCD Screen Replacement: 8 단계, 이미지 1/1
    • Use the J0 Phillips head screws to remove two 5mm long Phillips head screws from the plastic bracket holding LCD in place.
  9. Drift HD 720 LCD Screen Replacement: 9 단계, 이미지 1/1
    • Remove the LCD screen from the front cover.
  10. Drift HD 720 LCD Screen Replacement: 10 단계, 이미지 1/1
    • Slide the black bar toward the LCD screen in order to remove the screen from slot.
  11. Drift HD 720 LCD Screen Replacement: 11 단계, 이미지 1/1
    • Remove the LCD from motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Hector Rodriquez
회원 가입일: 09/23/15
422 평판
안내서 4개 작성하였습니다
Baylor, Team 10-16, Williams Fall 2015 Baylor, Team 10-16, Williams Fall 2015 회원
BU-WILLIAMS-F15S10G16
3 회원들
안내서 8개 작성하였습니다
댓글 4개
Did you now where to find the replacement LCD screen? Thanks.
Rodrigo Forrequi - 답글
I believe eBay should work.
Ruru Idahosa - 답글
need a ribbon for stealth 2 any ideas?
dennis - 답글
Good job! That guide indeed helped me a lot to give my Drift HD a good cleaning. Was a bit tough to remove the PCB, but after some fiddling it worked. Should be mentioned that you can remove the microphone from the surrounding rubber gasket so you can wash the gasket with ordinary soap. You can also separate the two PCBs (they are just stacked ontop of earch other using press-fit connectors)for easier access, e. g. if you want to clean and re-grease the collar of the lens unit. Also keep an eye on the aluminum cooler star. It has some heat conduction compond on it that you want to spread evenly. Don't wash it off entirely!
Volker Bartheld - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 1,141
