소개
If your device seems to be turning on but the screen isn't displaying anything, you may be able to fix the issue by replacing the screen.
필요한 것
Remove six 8mm long Philips head screws with the J0 Philips head from the outer case.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 4개
Did you now where to find the replacement LCD screen? Thanks.
I believe eBay should work.
Good job! That guide indeed helped me a lot to give my Drift HD a good cleaning. Was a bit tough to remove the PCB, but after some fiddling it worked. Should be mentioned that you can remove the microphone from the surrounding rubber gasket so you can wash the gasket with ordinary soap. You can also separate the two PCBs (they are just stacked ontop of earch other using press-fit connectors)for easier access, e. g. if you want to clean and re-grease the collar of the lens unit. Also keep an eye on the aluminum cooler star. It has some heat conduction compond on it that you want to spread evenly. Don't wash it off entirely!
