주요 콘텐츠로 건너뛰기
Drift HD 720 Microphone Replacement
필요한 것
  1. Drift HD 720 Microphone Replacement, Battery: 1 단계, 이미지 1/2 Drift HD 720 Microphone Replacement, Battery: 1 단계, 이미지 2/2
    • Unscrew the back plate counterclockwise until it comes off.
  2. Drift HD 720 Microphone Replacement: 2 단계, 이미지 1/1
    • Push the black battery tab next to the battery to get the battery out.
    • Remove the battery.
  3. Drift HD 720 Microphone Replacement, Microphone: 3 단계, 이미지 1/1
    • Remove six 8mm long Philips head screws with the J0 Philips head from the outer case.
  4. Drift HD 720 Microphone Replacement: 4 단계, 이미지 1/1
    • Remove the back case from the camera body.
  5. Drift HD 720 Microphone Replacement: 5 단계, 이미지 1/1
    • Remove the battery housing from the camera body.
  6. Drift HD 720 Microphone Replacement: 6 단계, 이미지 1/1
    • Remove the microphone first from the rubber housing it is located in, after which you will disconnect the wires connecting the microphone to the motherboard from where they are attached on the motherboard. You will then solder the new speakers wires in the same locations on the motherboard as the wires you just removed.
결론
Hector Rodriquez
회원 가입일: 09/23/15
422 평판
안내서 4개 작성하였습니다
Baylor, Team 10-16, Williams Fall 2015 Baylor, Team 10-16, Williams Fall 2015 회원
BU-WILLIAMS-F15S10G16
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 340
