주요 콘텐츠로 건너뛰기
Drift HD 720 Speaker Replacement
필요한 것
  1. Drift HD 720 Speaker Replacement, Battery: 1 단계, 이미지 1/2 Drift HD 720 Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • Unscrew the back plate counterclockwise until it comes off.
  2. Drift HD 720 Speaker Replacement: 2 단계, 이미지 1/1
    • Push the black battery tab next to the battery to get the battery out.
    • Remove the battery.
  3. Drift HD 720 Speaker Replacement, Speaker: 3 단계, 이미지 1/1
    • Remove six 8mm long Philips head screws with the J0 Philips head from the outer case.
  4. Drift HD 720 Speaker Replacement: 4 단계, 이미지 1/1
    • Remove the back case from the camera body.
  5. Drift HD 720 Speaker Replacement: 5 단계, 이미지 1/1
    • Carefully remove the battery housing from the camera body.
  6. Drift HD 720 Speaker Replacement: 6 단계, 이미지 1/1
    • Remove the wires connecting the speaker to the motherboard from the motherboard, and solder the wires connecting the new speaker to the motherboard in the same locations as the wires that were removed.
결론
Hector Rodriquez
회원 가입일: 09/23/15
422 평판
안내서 4개 작성하였습니다
Baylor, Team 10-16, Williams Fall 2015 Baylor, Team 10-16, Williams Fall 2015 회원
BU-WILLIAMS-F15S10G16
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 9
전체 시간: 205
