주요 콘텐츠로 건너뛰기
Drill Master Heat Gun Heating Coil Replacement
필요한 것
  1. Drill Master Heat Gun Heating Coil Replacement, Heating Coil: 1 단계, 이미지 1/1
    • Be sure the heat gun is unplugged before starting this process.
    • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
    • You will need a screwdriver extension.
  2. Drill Master Heat Gun Heating Coil Replacement: 2 단계, 이미지 1/1
    • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
    • Don't try to open the casing just yet.
  3. Drill Master Heat Gun Heating Coil Replacement: 3 단계, 이미지 1/3 Drill Master Heat Gun Heating Coil Replacement: 3 단계, 이미지 2/3 Drill Master Heat Gun Heating Coil Replacement: 3 단계, 이미지 3/3
    • Remove the barrel casing on either end by twisting and pulling each side off.
  4. Drill Master Heat Gun Heating Coil Replacement: 4 단계, 이미지 1/1
    • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
  5. Drill Master Heat Gun Heating Coil Replacement: 5 단계, 이미지 1/1
    • Remove the plastic casing from the end of the barrel.
  6. Drill Master Heat Gun Heating Coil Replacement: 6 단계, 이미지 1/1
    • Remove the metal casing from the heating element.
  7. Drill Master Heat Gun Heating Coil Replacement: 7 단계, 이미지 1/1
    • Slowly remove the heat resistant wrapping from the heating element.
    • Be careful here - the wrapping can be easily torn!
  8. Drill Master Heat Gun Heating Coil Replacement: 8 단계, 이미지 1/2 Drill Master Heat Gun Heating Coil Replacement: 8 단계, 이미지 2/2
    • Use the angled tweezers to remove the heating coil end from the input point.
  9. Drill Master Heat Gun Heating Coil Replacement: 9 단계, 이미지 1/1
    • Remove the heating coil by unraveling it from the heating element.
    • To replace, you'll need to re-wrap a new wire around the coil and attach it to the wires at the bottom (see Step 8).
결론
다른 2명이 해당 안내서를 완성하였습니다.
Mikayla Kim
회원 가입일: 01/31/17
523 평판
안내서 5개 작성하였습니다
University of North Texas, Team 1-2, Campbell Spring 2017 University of North Texas, Team 1-2, Campbell Spring 2017 회원
UNT-CAMPBELL-S17S1G2
3 회원들
안내서 10개 작성하였습니다
댓글 3개
Where are the heating coil wires found?
Thomas Frye - 답글
I am asking where I can find a NEW heating coil wire?
Thomas Frye - 답글
There is continuity in the heating coil wire, so I believe something else is causing my problem. There is one terminal on the heating element
that has a curved, rigid, bulbous hotdog shaped component that is right close to the terminal on the heating element. I am not sure what it is.
One can be seen in the picture at the top of the page in the introduction.
Thomas Frye - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 59
전체 시간: 4,101
