소개
If you're confident in your repair skills, use this guide to replace the heating coil in the heart of your heat gun.
필요한 것
Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
Use the angled tweezers to remove the heating coil end from the input point.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 3개
Where are the heating coil wires found?
I am asking where I can find a NEW heating coil wire?
There is continuity in the heating coil wire, so I believe something else is causing my problem. There is one terminal on the heating element
that has a curved, rigid, bulbous hotdog shaped component that is right close to the terminal on the heating element. I am not sure what it is.
One can be seen in the picture at the top of the page in the introduction.
