주요 콘텐츠로 건너뛰기
Drill Master Heat Gun Power Cord Replacement
필요한 것
  1. Drill Master Heat Gun Power Cord Replacement, Power Cord: 1 단계, 이미지 1/1
    • Be sure the heat gun is unplugged before starting this process.
    • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
    • You will need a screwdriver extension.
  2. Drill Master Heat Gun Power Cord Replacement: 2 단계, 이미지 1/1
    • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
    • Don't try to open the casing just yet.
  3. Drill Master Heat Gun Power Cord Replacement: 3 단계, 이미지 1/3 Drill Master Heat Gun Power Cord Replacement: 3 단계, 이미지 2/3 Drill Master Heat Gun Power Cord Replacement: 3 단계, 이미지 3/3
    • Remove the barrel casing on either end by twisting and pulling each side off.
  4. Drill Master Heat Gun Power Cord Replacement: 4 단계, 이미지 1/1
    • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
  5. Drill Master Heat Gun Power Cord Replacement: 5 단계, 이미지 1/1
    • Loosen four screws on the wire connector using the flathead 2.5 screwdriver.
    • Screws do not come out of connector.
  6. Drill Master Heat Gun Power Cord Replacement: 6 단계, 이미지 1/1
    • Disconnect the power cord wiring from the wire connector.
  7. Drill Master Heat Gun Power Cord Replacement: 7 단계, 이미지 1/1
    • Remove the two 12mm screws from the base of power cord using the PH#0 screwdriver.
  8. Drill Master Heat Gun Power Cord Replacement: 8 단계, 이미지 1/1
    • Remove the power cord from the heat gun.
결론
Mikayla Kim
회원 가입일: 01/31/17
523 평판
안내서 5개 작성하였습니다
University of North Texas, Team 1-2, Campbell Spring 2017 University of North Texas, Team 1-2, Campbell Spring 2017 회원
UNT-CAMPBELL-S17S1G2
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 656
