주요 콘텐츠로 건너뛰기
Driver Side Mirror Replacement on 2002 Chevrolet Tahoe
필요한 것
  1. Driver Side Mirror Replacement on 2002 Chevrolet Tahoe, Driver Side Mirror on 2002 Chevrolet Tahoe: 1 단계, 이미지 1/2 Driver Side Mirror Replacement on 2002 Chevrolet Tahoe, Driver Side Mirror on 2002 Chevrolet Tahoe: 1 단계, 이미지 2/2
    • Turn the mirror in towards the vehicle allowing access to the left side of the mirror.
    • This can be done either electronically from the inside of the vehicle or manually by applying force to the mirror.
  2. Driver Side Mirror Replacement on 2002 Chevrolet Tahoe: 2 단계, 이미지 1/1
    • Insert the screwdriver on the left side of the mirror and apply force to release.
  3. Driver Side Mirror Replacement on 2002 Chevrolet Tahoe: 3 단계, 이미지 1/3 Driver Side Mirror Replacement on 2002 Chevrolet Tahoe: 3 단계, 이미지 2/3 Driver Side Mirror Replacement on 2002 Chevrolet Tahoe: 3 단계, 이미지 3/3
    • Insert the screwdriver on the top of the mirror and apply force to release this section.
    • Repeat this step for the bottom portion along with the ride side of the mirror.
  4. Driver Side Mirror Replacement on 2002 Chevrolet Tahoe: 4 단계, 이미지 1/2 Driver Side Mirror Replacement on 2002 Chevrolet Tahoe: 4 단계, 이미지 2/2
    • Unclip all three wires and remove the old mirror from the module.
결론
To reassemble your new mirror, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Kyle Vallans
회원 가입일: 11/11/16
59 평판
안내서 1개 작성함
Missouri Western, Team 1-14, Adkins Fall 2016 Missouri Western, Team 1-14, Adkins Fall 2016 회원
MWSU-ADKINS-F16S1G14
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 21
전체 시간: 2,662
