주요 콘텐츠로 건너뛰기
Drobo FS DRDS2-A Power Switch Replacement
필요한 것
  1. Drobo FS DRDS2-A Power Switch Replacement, Case: 1 단계, 이미지 1/1
    • To start getting the case off remove the front panel so it's out of the way.
  2. Drobo FS DRDS2-A Power Switch Replacement: 2 단계, 이미지 1/2 Drobo FS DRDS2-A Power Switch Replacement: 2 단계, 이미지 2/2
    • Next remove the screws from the feet of the case with a phillips head screwdriver.
  3. Drobo FS DRDS2-A Power Switch Replacement: 3 단계, 이미지 1/1
    • To remove the case, place the Drobo on its back and slide the case off.
  4. Drobo FS DRDS2-A Power Switch Replacement, Power Switch: 4 단계, 이미지 1/3 Drobo FS DRDS2-A Power Switch Replacement, Power Switch: 4 단계, 이미지 2/3 Drobo FS DRDS2-A Power Switch Replacement, Power Switch: 4 단계, 이미지 3/3
    • Press tabs to release back cover and lift off
  5. Drobo FS DRDS2-A Power Switch Replacement: 5 단계, 이미지 1/2 Drobo FS DRDS2-A Power Switch Replacement: 5 단계, 이미지 2/2
    • Push tabs in and carefully pull out the front facer and drive shelves
  6. Drobo FS DRDS2-A Power Switch Replacement: 6 단계, 이미지 1/2 Drobo FS DRDS2-A Power Switch Replacement: 6 단계, 이미지 2/2
    • Unscrew the back face by removing the screw on the back sides, then slide top face apart from the others
    • If you have a Drobo 5N2, you may also need to remove the 3 screws on each side.
  7. Drobo FS DRDS2-A Power Switch Replacement: 7 단계, 이미지 1/2 Drobo FS DRDS2-A Power Switch Replacement: 7 단계, 이미지 2/2
    • Carefully unplug the Power Switch and Fan wires.
  8. Drobo FS DRDS2-A Power Switch Replacement: 8 단계, 이미지 1/1
    • Press tabs on Power Switch to release the Power Switch and Push out.
    • A Spudger like object is helpful for pushing in the tabs if the fan is not removed also
  9. Drobo FS DRDS2-A Power Switch Replacement: 9 단계, 이미지 1/2 Drobo FS DRDS2-A Power Switch Replacement: 9 단계, 이미지 2/2
    • Finally pull the old switch out and pop the new one in.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Rye Cassan
회원 가입일: 01/24/17
155 평판
안내서 1개 작성함
Cal Poly, Team 10-4, Banghart Winter 2017 Cal Poly, Team 10-4, Banghart Winter 2017 회원
CPSU-BANGHART-W17S10G4
3 회원들
안내서 5개 작성하였습니다
댓글 4개
Hello,
great info I found here, but where do I buy a replacement button for my Drobo in Europe?
Kind regards and thank you in advance,
Heinrich
Heinrich Voelkel - 답글
Hi, where do I find a replacement power switch for my Drobo 5N? BTW, thanks for the great tutorial!
Stephen R Parrott - 답글
I took my Drobo apart and the printed numbers on the switch are R13-112. I ordered these on Amazon:
https://www.amazon.com/Twidec-Rocker-Tog...
I put it in, crossed my fingers, and BAM, worked like a charm. Hope that helps all the future DIY’ers.
tdubs - 답글
Good article - thanks. Discovered my Drobo 5N (cir 2014) has a 3-wire spring-loaded switch with 2V LED (green) (wires: Red - White - Blue) Press once to turn on; Press and hold to manually turn off. Can simple R13-112 SPST switch be substituted?
John W - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 34
전체 시간: 2,192
