주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Droid MAXX 2 Screen Assembly Replacement
필요한 것
  1. Droid MAXX 2 Screen Assembly  Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
  2. Droid MAXX 2 Screen Assembly  Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the sim card tray up out of the phone
  3. Droid MAXX 2 Screen Assembly  Replacement: 3 단계, 이미지 2개 중 1개 Droid MAXX 2 Screen Assembly  Replacement: 3 단계, 이미지 2개 중 2개
    • Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
  4. Droid MAXX 2 Screen Assembly  Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
    • These may be T3 screws. If you are having trouble unscrewing these, stop and try a T3 bit.
  5. Droid MAXX 2 Screen Assembly  Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the mid-frame off of the phone.
    • Keep track of the on/off and volume buttons when you take the phone apart because they are likely to fall out when the halves are separated.
  6. Droid MAXX 2 Screen Assembly  Replacement: 6 단계, 이미지 3개 중 1개 Droid MAXX 2 Screen Assembly  Replacement: 6 단계, 이미지 3개 중 2개 Droid MAXX 2 Screen Assembly  Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the static tape covering the two connectors.
    • Use a spudger to disconnect the battery cables from the motherboard.
    • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
  7. Droid MAXX 2 Screen Assembly  Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the disconnected battery from the phone.
  8. Droid MAXX 2 Screen Assembly  Replacement, Screen Assembly: 8 단계, 이미지 2개 중 1개 Droid MAXX 2 Screen Assembly  Replacement, Screen Assembly: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • We will be removing these 3 ribbon cables.
    • Using an opening pick, lift the grey tab on the rear camera's ZIF connector. Remove the ribbon cable and the camera.
    • Use tweezers to lift up on the grey latch on the ZIF connector.
    • Remove the ribbon cable from the ZIF connector.
  9. Droid MAXX 2 Screen Assembly  Replacement: 9 단계, 이미지 2개 중 1개 Droid MAXX 2 Screen Assembly  Replacement: 9 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to lift up the black latch on the ZIF connector.
    • Pull the ribbon cable out of the ZIF connector.
  10. Droid MAXX 2 Screen Assembly  Replacement: 10 단계, 이미지 3개 중 1개 Droid MAXX 2 Screen Assembly  Replacement: 10 단계, 이미지 3개 중 2개 Droid MAXX 2 Screen Assembly  Replacement: 10 단계, 이미지 3개 중 3개
    • Using a metal spudger, work your way around the perimeter of the main board and screen.
    • There is a lot of adhesive between the two pieces, so be careful to try to remove the adhesive slowly in order to not break anything.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Burke Seggerman
회원 가입일: 03/18/18
704 평판
안내서 5개를 작성함
Baylor, Team S3-G4, Williams Spring 2018 Baylor, Team S3-G4, Williams Spring 2018 회원
BU-WILLIAMS-S18S3G4
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 42
전체 시간: 2,330
