소개
For this repair I replaced the LCD and Digitizer that comes with a frame. When ordering the part you should make sure it has the frame, because if you repair the front assembly without the frame, there will always be a slight lift in the screen. If you repair it without the frame it will still work, but you will run the risk of cracking the screen again due to that slight lift.
필요한 것
Start by removing the Sim card tray, which also happens to be your volume button
다른 17명이 해당 안내서를 완성하였습니다.
댓글 8개
I want to repair the scencor
I want to repair the XT1080 sciencer
Repair screen on droid ultra XT 1080
My Android 1080 screen is frozen. How can I get my photos?
