주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Droid Ultra XT1080 Front assembly with frame Replacement
필요한 것
  1. Droid Ultra XT1080 Front assembly with frame Replacement, Front assembly with frame: 1 단계, 이미지 1개 중 1개
    • Start by removing the Sim card tray, which also happens to be your volume button
    댓글 쓰기
  2. Droid Ultra XT1080 Front assembly with frame Replacement: 2 단계, 이미지 1개 중 1개
    • I personally used an iSesamo tool to unclip the tabs off the back housing, You can also use the Jimmy or some plastic prying tools.
    • Do Not pry the back housing around the bottom of the screen. Pry on the left, right, and top. After that the back housing should slide off on the bottom.
    댓글 쓰기
  3. Droid Ultra XT1080 Front assembly with frame Replacement: 3 단계, 이미지 3개 중 1개 Droid Ultra XT1080 Front assembly with frame Replacement: 3 단계, 이미지 3개 중 2개 Droid Ultra XT1080 Front assembly with frame Replacement: 3 단계, 이미지 3개 중 3개
    • T5 Torx screws
    • T3 Torx screw
    • T5 Torx screws
    • T5 Torx screws
    • When putting back together, do not tighten the screws too tight.
    댓글 쓰기
  4. Droid Ultra XT1080 Front assembly with frame Replacement: 4 단계, 이미지 1개 중 1개
    • T5 Torx screws
    댓글 쓰기
  5. Droid Ultra XT1080 Front assembly with frame Replacement: 5 단계, 이미지 2개 중 1개 Droid Ultra XT1080 Front assembly with frame Replacement: 5 단계, 이미지 2개 중 2개
    • T5 Torx screws
    댓글 쓰기
  6. Droid Ultra XT1080 Front assembly with frame Replacement: 6 단계, 이미지 3개 중 1개 Droid Ultra XT1080 Front assembly with frame Replacement: 6 단계, 이미지 3개 중 2개 Droid Ultra XT1080 Front assembly with frame Replacement: 6 단계, 이미지 3개 중 3개
    • With the iSesamo tool, or a prying tool, unclip the tabs on the left and right side of the phone.
    댓글 쓰기
  7. Droid Ultra XT1080 Front assembly with frame Replacement: 7 단계, 이미지 3개 중 1개 Droid Ultra XT1080 Front assembly with frame Replacement: 7 단계, 이미지 3개 중 2개 Droid Ultra XT1080 Front assembly with frame Replacement: 7 단계, 이미지 3개 중 3개
    • Using a Spudger lift the motherboard from right to left.
    • After lifting the motherboard from the frame remove the tape, and lift the black tab with your Spudger to remove the flex cable.
    • When you place the new screen remember to replace the tape over the flex cable.
    • Before putting the mother board on remember to transfer your ear speaker from the old frame to the new one.
    댓글 쓰기
  8. Droid Ultra XT1080 Front assembly with frame Replacement, And you are done...: 8 단계, 이미지 1개 중 1개
    • .... as long as you work your way backwards to put it back together.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 17명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Ricardo Martinez
회원 가입일: 10/19/14
751 평판
안내서 1개를 작성함
8가이드 댓글
I want to repair the scencor
Atihussan82 Hussain - 답글 공유
I want to repair the XT1080 sciencer
Repair screen on droid ultra XT 1080
churchy dezign - 답글 공유
I want to repair the camera on Droid turbo XT1080
King Bash - 답글 공유
My Android 1080 screen is frozen. How can I get my photos?
Madeline Rutledge - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 32
전체 시간: 5,215
