이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Drop-front desks, also known as slant-front desks, have a drop-front hinged panel. Users can open the panel by lowering it down to use as a writing surface. However, the connection between the main desk and the drop-front panel can experience damaged. The force of slamming down the drop-front panel repetitively to access the main cubby inside the desk can loosen screws, destabilize hinges and eventually lead to detachment.
If the drop-front is damaged, the desk's function is lost. For example, the drop-front desk will not provide a flat yet accessible platform to write on. Also, the drop-front will not raise back up towards the desk to make more room.
Reading this guide informs an audience how to repair a broken drop-front panel to restore the completeness and functionality of the panel and the overall desk. This repair requires lifting the panel and having another person assist in certain parts of the repair.
필요한 것
Position the hemispherical plates over the left hemispherical hole on the length of the panel.
Repeat this step with the right length of the panel.
Use the Phillips #2 screwdriver to turn the three #5 wood screws (15mm) and tighten the hemispherical plates along the length of the drop-front panel.
Position the second half of the rectangular plate over the four wood screw holes (15mm) on the left side of the inner desk frame.
Repeat this step with the right side of the inner desk frame.
Use the Phillips #2 screwdriver to screw the four #5 wood screws (15mm) and tighten the rectangular plate.
To disassemble your device, follow these instructions in reverse order.
