이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Position the rectangular plate over the Phillips #5 wood screw holes (15mm) on the left width.
Repeat this step with the right width of the panel.
Use the Phillips #2 screwdriver to turn the six Phillips #5 wood screws (15 mm) and secure the rectangular plates to the left width of the panel.
Position the hemispherical plates over the left hemispherical hole on the length of the panel.
Repeat this step with the right length of the panel.
Use the Phillips #2 screwdriver to turn the three #5 wood screws (15mm) and tighten the hemispherical plates along the length of the drop-front panel.
Position the panel's hemispherical plates over the hemispherical holes on the left and right side of the main desk frame.
Use the Phillips #2 screwdriver to turn the three Phillips #5 wood screws (15mm) and tighten the hemispherical hinges on the main desk frame.
Position the second half of the rectangular plate over the four wood screw holes (15mm) on the left side of the inner desk frame.
Repeat this step with the right side of the inner desk frame.
Use the Phillips #2 screwdriver to screw the four #5 wood screws (15mm) and tighten the rectangular plate.
Test the connection between the main desk frame and the drop-front panel by raising the panel towards the inner desk frame and away from it.
