주요 콘텐츠로 건너뛰기
Dual BT 10 Mainboard Disassembly
  1. Dual BT 10 Mainboard Disassembly, Removing bottom screws: 1 단계, 이미지 3개 중 1개 Dual BT 10 Mainboard Disassembly, Removing bottom screws: 1 단계, 이미지 3개 중 2개 Dual BT 10 Mainboard Disassembly, Removing bottom screws: 1 단계, 이미지 3개 중 3개
    • Unplug the device if needed and put the power switch into the "OFF" position.
    • Turn the device upside down
    • Remove the two foam feet at the front end of the speaker (the end with the buttons)
    • Unscrew the two screws revealed by the foam pads
  2. Dual BT 10 Mainboard Disassembly, Removing the top screw: 2 단계, 이미지 3개 중 1개 Dual BT 10 Mainboard Disassembly, Removing the top screw: 2 단계, 이미지 3개 중 2개 Dual BT 10 Mainboard Disassembly, Removing the top screw: 2 단계, 이미지 3개 중 3개
    • Turn the device in its normal position (standing on the foam feet)
    • Remove the screw cover using a thin blade at the front end of the device (the end with the buttons)
    • Unscrew the screw and remove it together with its plastic seating
  3. Dual BT 10 Mainboard Disassembly, Removing the front housing: 3 단계, 이미지 2개 중 1개 Dual BT 10 Mainboard Disassembly, Removing the front housing: 3 단계, 이미지 2개 중 2개
    • Gently pull the rubber strap to remove it from the silver front housing
    • Pull the silver front housing from the main body of the device
    • Do so gently as some cables are still connected inside the housing
  4. Dual BT 10 Mainboard Disassembly, Disconnecting the components: 4 단계, 이미지 2개 중 1개 Dual BT 10 Mainboard Disassembly, Disconnecting the components: 4 단계, 이미지 2개 중 2개
    • Disconnect all cables:
    • Take a picture of how everything is plugged in to make reassembling easier
    • Disconnect the battery first (fat red/black cable, red socket)
    • Disconnect the two front speakers (blue/white cables)
    • Disconnect the Subwoofer and LED cable (brown/black, red/black cables)
  5. Dual BT 10 Mainboard Disassembly, Removing the antenna wire: 5 단계, 이미지 1개 중 1개
    • Remove the red antenna wire by loosening it from the marked plastic taps
  6. Dual BT 10 Mainboard Disassembly, Unscrewing the front mesh: 6 단계, 이미지 3개 중 1개 Dual BT 10 Mainboard Disassembly, Unscrewing the front mesh: 6 단계, 이미지 3개 중 2개 Dual BT 10 Mainboard Disassembly, Unscrewing the front mesh: 6 단계, 이미지 3개 중 3개
    • Remove the four screws holding the front mesh
    • Separate the black plastic from the silver part
    • There is a cable connecting both parts! Be careful.
    • The mainboard is not screwed in place and will be loose after this step
    • Disconnect the brown cable from the small PCB to fully remove the black plastic
  7. Dual BT 10 Mainboard Disassembly, Removing the main board: 7 단계, 이미지 1개 중 1개
    • Pull out the main board from the assembly
    • Carefully feed the antenna wire through its small hole if needed
  8. Dual BT 10 Mainboard Disassembly, Reassembly: 8 단계, 이미지 1개 중 1개
    • To reassemble the device, follow all steps in reverse order
    • When reinserting the motherboard, be careful to place it inside the plastic guides in the black plastic / mesh cover
    • When pluging in all cables, it is recommended to plug in the battery last (thick red/black cable, red socket)
결론
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Skyfighter
회원 가입일: 08/28/23
439 평판
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 9
전체 시간: 163
