주요 콘텐츠로 건너뛰기
Dual Hard Drive #80
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. Dual Hard Drive #80, Dual Hard Drive: 1 단계, 이미지 1/2 Dual Hard Drive #80, Dual Hard Drive: 1 단계, 이미지 2/2
    • Remove the plastic spacer from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
  2. Dual Hard Drive #80: 2 단계, 이미지 1/3 Dual Hard Drive #80: 2 단계, 이미지 2/3 Dual Hard Drive #80: 2 단계, 이미지 3/3
    • Make sure that the hard drive connectors are facing down before placing it into the enclosure.
    • Gently place the hard drive into the enclosure's hard drive slot.
    • While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
  3. Dual Hard Drive #80: 3 단계, 이미지 1/2 Dual Hard Drive #80: 3 단계, 이미지 2/2
    • Once the hard drive is snug, reinsert the plastic spacer while holding the hard drive against the bottom of the enclosure.
  4. Dual Hard Drive #80: 4 단계, 이미지 1/2 Dual Hard Drive #80: 4 단계, 이미지 2/2
    • Use two Phillips #1 screws to secure the drive to its enclosure.
  5. Dual Hard Drive #80: 5 단계, 이미지 1/1
    • Attach the optical drive bracket to the new enclosure with two Phillips #0 screws.
    • Reconnect any cables you have removed from the original optical drive onto the optical bay enclosure.
  6. Dual Hard Drive #80: 6 단계, 이미지 1/3 Dual Hard Drive #80: 6 단계, 이미지 2/3 Dual Hard Drive #80: 6 단계, 이미지 3/3
    • Don't ditch that drive! You can still use your optical drive externally with the help of our SATA Optical Drive USB Cable.
    • Align the cable's SATA connector with the drive's port and plug in securely.
    • Plug the USB connector into your laptop and your optical drive is ready for use.
결론
Brittany McCrigler
회원 가입일: 03/05/12
89,017 평판
안내서 131개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 332
