주요 콘텐츠로 건너뛰기
DualSense Edge L1 and R1 Buttons Replacement
필요한 것
  1. DualSense Edge L1 and R1 Buttons Replacement, Remove the L1 and R1 buttons: 1 단계, 이미지 3개 중 1개 DualSense Edge L1 and R1 Buttons Replacement, Remove the L1 and R1 buttons: 1 단계, 이미지 3개 중 2개 DualSense Edge L1 and R1 Buttons Replacement, Remove the L1 and R1 buttons: 1 단계, 이미지 3개 중 3개
    • The L1 and R1 buttons are held in by two clips. If only one clip releases, move your spudger to the other side of the button to release the remaining clip. Don't continue prying on one side after a clip is released, or you risk breaking the other clip.
    • Insert the flat end of a spudger in the gap between the L1 and L2 buttons.
    • The buttons tend to shoot out in the next step. You can place your thumb over the button to prevent this.
    • Use the spudger to pry out and remove the L1 button.
    • Repeat this process to remove the R1 button.
결론
Spencer Pennington
회원 가입일: 09/09/23
23,443 평판
안내서 125개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 15,931개를 작성함
1가이드 댓글
Where can I buy a quality replacement for the r1 button, I bought some but they don't fit properly
Fly - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 39
지난 30일: 185
전체 시간: 2,371
