주요 콘텐츠로 건너뛰기
DualShock 2 D-Pad Replacement
필요한 것
  1. DualShock 2 D-Pad Replacement, D-Pad: 1 단계, 이미지 1/3 DualShock 2 D-Pad Replacement, D-Pad: 1 단계, 이미지 2/3 DualShock 2 D-Pad Replacement, D-Pad: 1 단계, 이미지 3/3
    • Turn the controller over.
    • Unscrew the six screws using your Phillips #00 screwdriver.
  2. DualShock 2 D-Pad Replacement: 2 단계, 이미지 1/3 DualShock 2 D-Pad Replacement: 2 단계, 이미지 2/3 DualShock 2 D-Pad Replacement: 2 단계, 이미지 3/3
    • Remove the back cover from the controller.
    • Slide the triggers off by pulling the trigger off the controller and repeat for another side.
  3. DualShock 2 D-Pad Replacement: 3 단계, 이미지 1/3 DualShock 2 D-Pad Replacement: 3 단계, 이미지 2/3 DualShock 2 D-Pad Replacement: 3 단계, 이미지 3/3
    • Remove the circuit board carefully.
    • Make sure not to touch any vital components and only grab them by the side.
  4. DualShock 2 D-Pad Replacement: 4 단계, 이미지 1/3 DualShock 2 D-Pad Replacement: 4 단계, 이미지 2/3 DualShock 2 D-Pad Replacement: 4 단계, 이미지 3/3
    • Remove the yellow rubber from the D-pad.
    • Remove the black plastic bracket with a pair of tweezers.
  5. DualShock 2 D-Pad Replacement: 5 단계, 이미지 1/3 DualShock 2 D-Pad Replacement: 5 단계, 이미지 2/3 DualShock 2 D-Pad Replacement: 5 단계, 이미지 3/3
    • Remove the broken D-pad from the controller carefully.
  6. DualShock 2 D-Pad Replacement: 6 단계, 이미지 1/3 DualShock 2 D-Pad Replacement: 6 단계, 이미지 2/3 DualShock 2 D-Pad Replacement: 6 단계, 이미지 3/3
    • Put the replacement D-pad in the controller.
    • Make sure to get replacement parts designed for your controller as sizes may vary.
    • Put the plastic bracket back on carefully.
  7. DualShock 2 D-Pad Replacement: 7 단계, 이미지 1/3 DualShock 2 D-Pad Replacement: 7 단계, 이미지 2/3 DualShock 2 D-Pad Replacement: 7 단계, 이미지 3/3
    • Replace the yellow rubber.
    • Carefully insert the circuit board and reclip the triggers.
    • Make sure to insert the analog sticks through the designed opening.
    • Insert the back cover back in place.
  8. DualShock 2 D-Pad Replacement: 8 단계, 이미지 1/3 DualShock 2 D-Pad Replacement: 8 단계, 이미지 2/3 DualShock 2 D-Pad Replacement: 8 단계, 이미지 3/3
    • Screw the back cover on again clockwise.
    • Test D-pad to make sure its in working order.
결론
Enjoy your new D-pad.
다른 3명이 해당 안내서를 완성하였습니다.
Gilberto Rosales
회원 가입일: 08/23/22
211 평판
안내서 1개 작성함
CSU Los Angeles, Team 3-77, Briggs Fall 2022 CSU Los Angeles, Team 3-77, Briggs Fall 2022 회원
CSULA-BRIGGS-F22S3G77
1 회원
안내서 2개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 80
30일 전: 325
전체 시간: 874
