주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
DualShock 3 Battery Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. DualShock 3 Battery Replacement, Grab your Controller: 1 단계, 이미지 1/1
    • Insert wisdom here.
  2. DualShock 3 Battery Replacement, Grab Pliers, and a Philips Screwdriver: 2 단계, 이미지 1/2 DualShock 3 Battery Replacement, Grab Pliers, and a Philips Screwdriver: 2 단계, 이미지 2/2
  3. DualShock 3 Battery Replacement, Turn Over the Controller: 3 단계, 이미지 1/1
    • Easiest Step Ever!
  4. DualShock 3 Battery Replacement, Unscrew the 5 screws in the back of the controller: 4 단계, 이미지 1/1
    • The screws are located in the holes of the in the back of the controller. (The holes are located on the left, and right controller hand grip, and the other hole is located between the left and right triggers)
  5. DualShock 3 Battery Replacement, Take off the Backplate: 5 단계, 이미지 1/1
    • If you have already taken out the screws the back-plate will lift up easily, whilst lifting gently push towards the triggers of the controller, to bypass them.
  6. DualShock 3 Battery Replacement, Taking out the battery: 6 단계, 이미지 1/1
    • Lift up the battery, and move it away from the motherboard(the green board). Next you need to grab your pliers, and grip onto the piece of plastic that the wires lead to, be sure not to grab the socket that holds this plastic piece, and don't grab the wires. Once you have it you should slowly wiggle the plastic piece out of the socket.
  7. DualShock 3 Battery Replacement, Installing the new battery: 7 단계, 이미지 1/1
    • To install the new battery, all you need to to do is grab the plastic part of the battery with your pliers and insert it into the socket that the old battery was in, make sure that the plastic piece is in all the way.
  8. DualShock 3 Battery Replacement, Putting back on the Backplate: 8 단계, 이미지 1/1
    • It is a little hard to put back on, but not impossible. You need to put it on over the R2, and L2 triggers, then you should push down on the back plate till' is snaps into place.
  9. DualShock 3 Battery Replacement, Screw in the 5 Screws: 9 단계, 이미지 1/1
    • Once the 5 Screws are tightly screwed in you are done with the replacement of the battery.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Noble Foley
회원 가입일: 11/05/16
218 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 937
