주요 콘텐츠로 건너뛰기
DualShock 3 Rear Cover Replacement
필요한 것
  1. DualShock 3 Rear Cover Replacement, Rear Cover: 1 단계, 이미지 1/1
    • Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
  2. DualShock 3 Rear Cover Replacement: 2 단계, 이미지 1/1
    • Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
  3. DualShock 3 Rear Cover Replacement: 3 단계, 이미지 1/2 DualShock 3 Rear Cover Replacement: 3 단계, 이미지 2/2
    • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
    • Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
    • If you happen to accidentally pop off the trigger buttons, we have a trigger button guide to reattach them.
결론
다른 24명이 해당 안내서를 완성하였습니다.
Andrew Bookholt
586,200 평판
안내서 619개 작성하였습니다
댓글 3개
i have a different dualshock 3 than yours. mine is built in a different way and has a different battery
MasterKlaus Produtions (Swe0b) - 답글
Sony did that throughout the Dualshock 3’s production as they found out what would cause them to malfunction and fixed the issue. It should be alright as long as you are able to replace the battery when needed.
Aiodensghost -
iran:
نحوهی تعویض طلق دسته پلی سه هم بذارین. لطفان
مجید محمدی - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 16
30일 전: 70
전체 시간: 23,785
