이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to remove the rear cover of a DualShock 3 controller.
필요한 것
Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
다른 24명이 해당 안내서를 완성하였습니다.
댓글 3개
i have a different dualshock 3 than yours. mine is built in a different way and has a different battery
Sony did that throughout the Dualshock 3’s production as they found out what would cause them to malfunction and fixed the issue. It should be alright as long as you are able to replace the battery when needed.
iran:
نحوهی تعویض طلق دسته پلی سه هم بذارین. لطفان
مجید محمدی - 답글
