이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
다른 24명이 해당 안내서를 완성하였습니다.
댓글 3개
i have a different dualshock 3 than yours. mine is built in a different way and has a different battery
Sony did that throughout the Dualshock 3’s production as they found out what would cause them to malfunction and fixed the issue. It should be alright as long as you are able to replace the battery when needed.
iran:
نحوهی تعویض طلق دسته پلی سه هم بذارین. لطفان
مجید محمدی - 답글
