주요 콘텐츠로 건너뛰기
DualShock 4 CHU-ZCT2U Buttons Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. DualShock 4 CHU-ZCT2U Buttons Replacement, Outer Shell: 1 단계, 이미지 1/3 DualShock 4 CHU-ZCT2U Buttons Replacement, Outer Shell: 1 단계, 이미지 2/3 DualShock 4 CHU-ZCT2U Buttons Replacement, Outer Shell: 1 단계, 이미지 3/3
    • Unscrew the four 6.5mm screws, using a Phillips-Head screwdriver.
    • Pry the two halves of the shell apart using a plastic opening tool.
    • Be careful, as there will be a ribbon connecting the inner workings of the controller. It will not separate into two parts just by pulling apart the shell.
  2. DualShock 4 CHU-ZCT2U Buttons Replacement: 2 단계, 이미지 1/3 DualShock 4 CHU-ZCT2U Buttons Replacement: 2 단계, 이미지 2/3 DualShock 4 CHU-ZCT2U Buttons Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers.
  3. DualShock 4 CHU-ZCT2U Buttons Replacement, Battery: 3 단계, 이미지 1/3 DualShock 4 CHU-ZCT2U Buttons Replacement, Battery: 3 단계, 이미지 2/3 DualShock 4 CHU-ZCT2U Buttons Replacement, Battery: 3 단계, 이미지 3/3
    • Unplug the black and red wires from the power port located on the motherboard.
    • Remove the old battery from the controller.
  4. DualShock 4 CHU-ZCT2U Buttons Replacement: 4 단계, 이미지 1/2 DualShock 4 CHU-ZCT2U Buttons Replacement: 4 단계, 이미지 2/2
    • Remove the 6.43mm screw connecting the motherboard to the inner workings of the controller, using a Phillips-Head screwdriver.
  5. DualShock 4 CHU-ZCT2U Buttons Replacement: 5 단계, 이미지 1/3 DualShock 4 CHU-ZCT2U Buttons Replacement: 5 단계, 이미지 2/3 DualShock 4 CHU-ZCT2U Buttons Replacement: 5 단계, 이미지 3/3
    • Unhook the battery case from the motherboard, and pull it off.
  6. DualShock 4 CHU-ZCT2U Buttons Replacement, Buttons: 6 단계, 이미지 1/3 DualShock 4 CHU-ZCT2U Buttons Replacement, Buttons: 6 단계, 이미지 2/3 DualShock 4 CHU-ZCT2U Buttons Replacement, Buttons: 6 단계, 이미지 3/3
    • Pull out the second ribbon cable to separate the inner workings from the top of the outer shell.
  7. DualShock 4 CHU-ZCT2U Buttons Replacement: 7 단계, 이미지 1/3 DualShock 4 CHU-ZCT2U Buttons Replacement: 7 단계, 이미지 2/3 DualShock 4 CHU-ZCT2U Buttons Replacement: 7 단계, 이미지 3/3
    • Remove the rubber pads that secure the buttons in place for the arrow buttons, shape buttons, and Playstation Home button.
    • Do not turn the front shell cover upside down after completing this step, because some of the buttons may fall out.
  8. DualShock 4 CHU-ZCT2U Buttons Replacement: 8 단계, 이미지 1/2 DualShock 4 CHU-ZCT2U Buttons Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove the old buttons, and replace them with new ones using a pair of tweezers.
결론
다른 41명이 해당 안내서를 완성하였습니다.
Michelle Joseph
회원 가입일: 10/09/17
1,762 평판
안내서 3개 작성하였습니다
USF Tampa, Team S1-G5, Leahy Fall 2017 USF Tampa, Team S1-G5, Leahy Fall 2017 회원
USFT-LEAHY-F17S1G5
3 회원들
안내서 22개 작성하였습니다
댓글 2개
Where can I buy cuh zct2e spares from please
Paramdeep Dhaliwal - 답글
Can’t see an updated guide, and this one worked perfectly fine. Used to replace the buttons on a knock-off DualShock 4 from AliExpress. Construction was largely the same, only devoid of a screw anchoring the battery cradle. Would argue this was an extremely easy repair!
Casey - 답글
댓글 쓰기
조회 통계:
24 시간 전: 12
7일 전: 104
30일 전: 381
전체 시간: 28,254
