필요한 것
Unscrew the four 6.5mm screws, using a Phillips-Head screwdriver.
Pry the two halves of the shell apart using a plastic opening tool.
Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers.
If you just want to change the battery, this step is not necessary; it can be done without disconnecting the ribbon cable.
Unplug the black and red wires from the power port located on the motherboard.
Remove the old battery from the controller.
Be extra careful - the power port socket pulled loose from the motherboard for me. I would suggest holding down the socket itself with one tool and gradually loosening the plug from the port.
Remove the 6.43mm screw connecting the motherboard to the inner workings of the controller, using a Phillips-Head screwdriver.
this and the last step arnt necessary you just put the battery back and connect all of it up
Joe Flores - 답글
Pull out the second ribbon cable to separate the inner workings from the top of the outer shell.
다른 41명이 해당 안내서를 완성하였습니다.
댓글 2개
Where can I buy cuh zct2e spares from please
When re-asembling, be careful to check that all buttons/triggers are moving correctly. They can get misaligned when prying the two shell halves apart.
Tale Spinner - 답글
This part is missing vital information on how to correctly pry the case open. In the 3rd picture you can see there is actually damaged/broken clip already. In order to open the case without damage to the plastic clips inside the controller holding the plastics together you need to insert thin piece of metal between the trigger buttons on each side and push the clip outwards before trying to separate the parts, and if done correctly there is no force needed to pry open the controller. There is actually no necessary need for the clips, but if you want to keep your controller in mint condition without voiding the warranty, take care not to break these clips.
Ville Närhi - 답글
Your advice for opening shell was so bad and harmful.
It's not correct
Kiarash Moallemi - 답글
And two more tiny clips to the left and right of the headphone & EXT port. They’re VERY delicate, reckless prying WILL break at least ONE of these.
Strings Cat - 답글
I've written a guide for how to find and unlatch the clips
Important Step For Opening the DualShock 4 CUH-ZCT2U
Richard - 답글
