주요 콘텐츠로 건너뛰기
DualShock 4 CHU-ZCT2U Charging Assembly Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. DualShock 4 CHU-ZCT2U Charging Assembly Replacement, Charging Assembly(LED and USB port chip): 1 단계, 이미지 1/3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement, Charging Assembly(LED and USB port chip): 1 단계, 이미지 2/3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement, Charging Assembly(LED and USB port chip): 1 단계, 이미지 3/3
    • Remove the 4 screws (6.0 mm), which is on the back of the controller, using Phillips #00 screwdriver
    • Place the removed screws to the side.
  2. DualShock 4 CHU-ZCT2U Charging Assembly Replacement: 2 단계, 이미지 1/3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: 2 단계, 이미지 2/3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: 2 단계, 이미지 3/3
    • Detach the top frame from the bottom frame by carefully pulling them apart.
  3. DualShock 4 CHU-ZCT2U Charging Assembly Replacement: 3 단계, 이미지 1/2 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: 3 단계, 이미지 2/2
    • Carefully remove the white ribbon connector that is connected to both frames from the top side ( the side where the battery is).
  4. DualShock 4 CHU-ZCT2U Charging Assembly Replacement: 4 단계, 이미지 1/3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: 4 단계, 이미지 2/3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: 4 단계, 이미지 3/3
    • Take the bottom part (the side without the battery).
    • Remove the white plastic cover which is on the top of the Charging assembly.
  5. DualShock 4 CHU-ZCT2U Charging Assembly Replacement: 5 단계, 이미지 1/3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: 5 단계, 이미지 2/3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: 5 단계, 이미지 3/3
    • Remove the plastic cover which is in front of the Charging assembly.
    • Remove the transparent plastic cover which is on top of the Charging assembly.
    • Be careful while removing all plastic covers since they are very delicate and can break if removed forcefully.
  6. DualShock 4 CHU-ZCT2U Charging Assembly Replacement: 6 단계, 이미지 1/3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: 6 단계, 이미지 2/3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: 6 단계, 이미지 3/3
    • Remove the two screw (4.00 mm) using the #00 Phillips screwdriver, which is holding the Charging assembly and the frame together.
    • Remove the double-sided tape, with the plastic opening tool, that is keeping the chip attached to the frame.
    • Take out the charging assembly chip.
  7. DualShock 4 CHU-ZCT2U Charging Assembly Replacement: 7 단계, 이미지 1/3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: 7 단계, 이미지 2/3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: 7 단계, 이미지 3/3
    • Remove the white ribbon cable from the charging assembly chip.
    • Replace the Charging assembly chip with a new one.
결론
If you have followed all the steps correctly, your LED Light should light up once you reassemble and plug your device to a USB cord. To reassemble your device, follow these instructions in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
Surinderjit Singh
회원 가입일: 06/19/19
217 평판
안내서 1개 작성함
University of Memphis, Team S1-G3, Lane Summer 2019 University of Memphis, Team S1-G3, Lane Summer 2019 회원
UM-LANE-SU19S1G3
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 3,053
