주요 콘텐츠로 건너뛰기
소개
Follow this guide to replace the motherboard and midframe assembly on a Sony Dualshock 4 CHU-ZCT2U PlayStation controller.
  1. Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel. Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
  2. Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle. Gently pry the rear panel off of the front panel until they become partially separated.
    • Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
    • Gently pry the rear panel off of the front panel until they become partially separated.
  3. Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller. Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller. Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
    • Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
  4. Lift the rear panel directly away from the controller. Do not completely remove the rear panel. It is still attached to the controller by a ribbon cable.
    • Lift the rear panel directly away from the controller.
    • Do not completely remove the rear panel. It is still attached to the controller by a ribbon cable.
  5. Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard. Since this cable's pull tab is too small to grab with fingers or tweezers, grab the cable itself. Otherwise utilize pull tabs whenever possible.
    • Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard.
    • Since this cable's pull tab is too small to grab with fingers or tweezers, grab the cable itself. Otherwise utilize pull tabs whenever possible.
    • During reassembly, grab the ribbon cable by the blue tab and gently press the cable straight into the connector. Push the blue tab rather than the ribbon cable itself.
  6. Use a pair of tweezers to pull the battery's power connector straight up from the motherboard. Use a pair of tweezers to pull the battery's power connector straight up from the motherboard.
    • Use a pair of tweezers to pull the battery's power connector straight up from the motherboard.
  7. Remove the battery. Remove the battery.
    • Remove the battery.
  8. Use a Phillips screwdriver to remove the 6.4 mm-long screw securing the battery bracket. Use a Phillips screwdriver to remove the 6.4 mm-long screw securing the battery bracket.
    • Use a Phillips screwdriver to remove the 6.4 mm-long screw securing the battery bracket.
  9. Remove the battery bracket. Remove the battery bracket.
    • Remove the battery bracket.
  10. Use a pair of tweezers to disconnect the touch panel ribbon cable. Pull the ribbon cable directly away from its connector on the motherboard by the blue pull tab, not by the cable itself.
    • Use a pair of tweezers to disconnect the touch panel ribbon cable.
    • Pull the ribbon cable directly away from its connector on the motherboard by the blue pull tab, not by the cable itself.
  11. Separate the motherboard and midframe assembly from the front panel. Separate the motherboard and midframe assembly from the front panel.
    • Separate the motherboard and midframe assembly from the front panel.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Sam Omiotek
회원 가입일: 2019년 02월 25일
39,273 평판
안내서 234개 작성하였습니다
iFixit iFixit 회원
Community
146 회원들
안내서 17,094개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 62
30일 전: 337
전체 시간: 5,439
