소개
Follow this guide to replace the touchpad on a Sony Dualshock 4 CHU-ZCT2U PlayStation controller.
필요한 것
Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
Gently pry the rear panel off of the front panel until they become partially separated.
Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
Use a pair of tweezers to pull the battery's power connector straight up from the motherboard.
Use a Phillips screwdriver to remove the 6.4 mm-long screw securing the battery bracket.
Push the bottom of the touchpad in from the front side of the controller to separate it from the front case.
Remove the touchpad from the bezel holding it to the front case.
다른 한 분이 해당 안내서를 완성하였습니다.
