주요 콘텐츠로 건너뛰기
DualShock 4 CUH-ZCT1 Charging Port Replacement
필요한 것
  1. DualShock 4 CUH-ZCT1 Charging Port Replacement, Charging Port: 1 단계, 이미지 1/1
    • Flip the Dualshock 4 controller on its back, and use a Phillips #00 screwdriver to remove the four 6 mm screws.
  2. DualShock 4 CUH-ZCT1 Charging Port Replacement: 2 단계, 이미지 1/1
    • Slowly lift the backplate onto the front side of the controller making sure not to fully remove the backplate.
  3. DualShock 4 CUH-ZCT1 Charging Port Replacement: 3 단계, 이미지 1/2 DualShock 4 CUH-ZCT1 Charging Port Replacement: 3 단계, 이미지 2/2
    • Remove the ribbon cable from the motherboard of the controller and place the top half of the controller on the side for later.
  4. DualShock 4 CUH-ZCT1 Charging Port Replacement: 4 단계, 이미지 1/1
    • Remove the light bar's sub-assembly by gently lifting up the piece.
  5. DualShock 4 CUH-ZCT1 Charging Port Replacement: 5 단계, 이미지 1/1
    • Lift the clear plastic piece out of the controller by pulling into the controller and removing it.
  6. DualShock 4 CUH-ZCT1 Charging Port Replacement: 6 단계, 이미지 1/1
    • Remove the two 6 mm Phillips screws that are on top of the PCB of the charging port.
  7. DualShock 4 CUH-ZCT1 Charging Port Replacement: 7 단계, 이미지 1/2 DualShock 4 CUH-ZCT1 Charging Port Replacement: 7 단계, 이미지 2/2
    • Gently wiggle the charging port's PCB side to side until it detaches from the controller.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Andy Lam
회원 가입일: 01/31/23
307 평판
안내서 1개 작성함
York University, Team P-10, Allen Fall 2022 York University, Team P-10, Allen Fall 2022 회원
YORK-ALLEN-F22SPG10
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 57
30일 전: 256
전체 시간: 3,150
