주요 콘텐츠로 건너뛰기
DualShock 4 CUH-ZCT2 Front Panel Replacement
필요한 것
  1. DualShock 4 CUH-ZCT2 Front Panel Replacement, Remove the rear panel screws: 1 단계, 이미지 2개 중 1개 DualShock 4 CUH-ZCT2 Front Panel Replacement, Remove the rear panel screws: 1 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
  2. DualShock 4 CUH-ZCT2 Front Panel Replacement, Separate the rear panel: 2 단계, 이미지 2개 중 1개 DualShock 4 CUH-ZCT2 Front Panel Replacement, Separate the rear panel: 2 단계, 이미지 2개 중 2개
    • Four fragile plastic clips hold the panels together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
    • Gently pry the rear panel off of the front panel until they become partially separated.
  3. DualShock 4 CUH-ZCT2 Front Panel Replacement, Release the plastic clips: 3 단계, 이미지 3개 중 1개 DualShock 4 CUH-ZCT2 Front Panel Replacement, Release the plastic clips: 3 단계, 이미지 3개 중 2개 DualShock 4 CUH-ZCT2 Front Panel Replacement, Release the plastic clips: 3 단계, 이미지 3개 중 3개
    • Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
  4. DualShock 4 CUH-ZCT2 Front Panel Replacement, Remove the rear panel: 4 단계, 이미지 2개 중 1개 DualShock 4 CUH-ZCT2 Front Panel Replacement, Remove the rear panel: 4 단계, 이미지 2개 중 2개
    • Lift the rear panel directly away from the controller.
    • Do not completely remove the rear panel. It is still attached to the controller by a ribbon cable.
  5. DualShock 4 CUH-ZCT2 Front Panel Replacement: 5 단계, 이미지 2개 중 1개 DualShock 4 CUH-ZCT2 Front Panel Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard.
    • Since this cable's pull tab is too small to grab with fingers or tweezers, grab the cable itself. Otherwise utilize pull tabs whenever possible.
    • During reassembly, grab the ribbon cable by the blue tab and gently press the cable straight into the connector. Push the blue tab rather than the ribbon cable itself.
  6. DualShock 4 CUH-ZCT2 Front Panel Replacement, Remove the battery: 6 단계, 이미지 2개 중 1개 DualShock 4 CUH-ZCT2 Front Panel Replacement, Remove the battery: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to pull the battery's power connector straight up from the motherboard.
  7. DualShock 4 CUH-ZCT2 Front Panel Replacement: 7 단계, 이미지 2개 중 1개 DualShock 4 CUH-ZCT2 Front Panel Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the battery.
  8. DualShock 4 CUH-ZCT2 Front Panel Replacement, Remove the motherboard: 8 단계, 이미지 2개 중 1개 DualShock 4 CUH-ZCT2 Front Panel Replacement, Remove the motherboard: 8 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the 6.4 mm-long screw securing the battery bracket.
  9. DualShock 4 CUH-ZCT2 Front Panel Replacement: 9 단계, 이미지 2개 중 1개 DualShock 4 CUH-ZCT2 Front Panel Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the battery bracket.
  10. DualShock 4 CUH-ZCT2 Front Panel Replacement: 10 단계, 이미지 2개 중 1개 DualShock 4 CUH-ZCT2 Front Panel Replacement: 10 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to disconnect the touch panel ribbon cable.
    • Pull the ribbon cable directly away from its connector on the motherboard by the blue pull tab, not by the cable itself.
  11. DualShock 4 CUH-ZCT2 Front Panel Replacement: 11 단계, 이미지 2개 중 1개 DualShock 4 CUH-ZCT2 Front Panel Replacement: 11 단계, 이미지 2개 중 2개
    • Separate the motherboard and midframe assembly from the front panel.
  12. DualShock 4 CUH-ZCT2 Front Panel Replacement, Remove the touchpad: 12 단계, 이미지 3개 중 1개 DualShock 4 CUH-ZCT2 Front Panel Replacement, Remove the touchpad: 12 단계, 이미지 3개 중 2개 DualShock 4 CUH-ZCT2 Front Panel Replacement, Remove the touchpad: 12 단계, 이미지 3개 중 3개
    • Push the bottom of the touchpad in from the front side of the controller to separate it from the front case.
    • Remove the touchpad from the bezel holding it to the front case.
  13. DualShock 4 CUH-ZCT2 Front Panel Replacement, Remove the buttons: 13 단계, 이미지 3개 중 1개 DualShock 4 CUH-ZCT2 Front Panel Replacement, Remove the buttons: 13 단계, 이미지 3개 중 2개 DualShock 4 CUH-ZCT2 Front Panel Replacement, Remove the buttons: 13 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use your fingers or a pair of tweezers to remove the three silicone conductive rubber pads from the controller buttons.
  14. DualShock 4 CUH-ZCT2 Front Panel Replacement: 14 단계, 이미지 2개 중 1개 DualShock 4 CUH-ZCT2 Front Panel Replacement: 14 단계, 이미지 2개 중 2개
    • Slowly turn over the front panel to let the buttons fall out.
    • Only the front panel remains.
    • The round buttons have unique notches designed to prevent them from being installed incorrectly.
  15. DualShock 4 CUH-ZCT2 Front Panel Replacement, Reassembly tip: 15 단계, 이미지 2개 중 1개 DualShock 4 CUH-ZCT2 Front Panel Replacement, Reassembly tip: 15 단계, 이미지 2개 중 2개
    • During reassembly, use your fingers or a pair of tweezers to drop the buttons into their respective holes on the front panel.
    • Align the button notches to ensure each one is fully inserted and in the correct location.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Sam Omiotek
회원 가입일: 02/25/19
92,501 평판
안내서 290개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 26
지난 30일: 93
전체 시간: 5,513
