주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
DualShock 4 Charging Port Replacement
필요한 것
  1. DualShock 4 Charging Port Replacement, Controller: 1 단계, 이미지 1/1
    • Using the Phillips #00 Screwdriver, remove the four 6.0 mm screws securing the rear cover to the controller.
    • Be careful loosening the screws, using the wrong sized screwdriver, or letting the screwdriver slip can permanently damage the screw heads, making removal extremely difficult.
  2. DualShock 4 Charging Port Replacement: 2 단계, 이미지 1/3 DualShock 4 Charging Port Replacement: 2 단계, 이미지 2/3 DualShock 4 Charging Port Replacement: 2 단계, 이미지 3/3
    • Four fragile plastic clips hold the casing together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Beginning with the left handle:
    • Pinch the left handle of the controller to introduce an opening.
    • Wedge a plastic opening tool into the opening and slide it up towards the joystick.
    • Pull down on tool to pry open the casing.
    • Repeat these steps for the right handle.
  3. DualShock 4 Charging Port Replacement: 3 단계, 이미지 1/3 DualShock 4 Charging Port Replacement: 3 단계, 이미지 2/3 DualShock 4 Charging Port Replacement: 3 단계, 이미지 3/3
    • Wedge a plastic opening tool into the case-splittings and pull down to crack open the casing near the following buttons:
    • Share button
    • Options button
    • Split the plastic covers of the controller apart, taking note that they will still be attached by circuit board ribbons.
    • Three small pieces are often released from the framework. To prevent loss, maintain a controlled work field.
    • 2 Trigger Springs
    • 1 Grey Reset Button Extension
  4. DualShock 4 Charging Port Replacement, Charging Port: 4 단계, 이미지 1/3 DualShock 4 Charging Port Replacement, Charging Port: 4 단계, 이미지 2/3 DualShock 4 Charging Port Replacement, Charging Port: 4 단계, 이미지 3/3
    • Detach the motherboard ribbon connecting the two sides of the controller by using your fingers.
    • After the two halves are separated, place the top of the controller off to the side.
  5. DualShock 4 Charging Port Replacement: 5 단계, 이미지 1/3 DualShock 4 Charging Port Replacement: 5 단계, 이미지 2/3 DualShock 4 Charging Port Replacement: 5 단계, 이미지 3/3
    • Remove the two screws holding the sub-assembly together. Then use the blunt forceps to grab the 2 inch black plastic connector labeled in the picture with the red box.
    • Use the blunt forceps to grab the 2 inch white piece of plastic labeled with the orange box.
  6. DualShock 4 Charging Port Replacement: 6 단계, 이미지 1/3 DualShock 4 Charging Port Replacement: 6 단계, 이미지 2/3 DualShock 4 Charging Port Replacement: 6 단계, 이미지 3/3
    • With the clear piece of plastic pushed in, take the transparent white piece out from the top of the controller.
    • Keep the clear plastic piece on the controller, but keep it pushed down to provide room for charger port replacement.
    • Use the Philips #00 Screwdriver to unscrew the two 4.0 mm screws that attach the charging port to the rear cover.
  7. DualShock 4 Charging Port Replacement: 7 단계, 이미지 1/3 DualShock 4 Charging Port Replacement: 7 단계, 이미지 2/3 DualShock 4 Charging Port Replacement: 7 단계, 이미지 3/3
    • With the blunt forceps remove the top part of the black tape connecting the charging port to the plastic portion of the controller.
    • Grab the PCB of the charging port from the side and pull upwards slowly to remove from the controller.
    • Do NOT pull the blue PCB rapidly upwards; instead move the piece side to side to create some free space between the controller and PCB.
결론
다른 95명이 해당 안내서를 완성하였습니다.
Bijan Vakilifathi
회원 가입일: 01/21/14
1,687 평판
안내서 1개 작성함
Cal Poly, Team 6-21, Maness Winter 2014 Cal Poly, Team 6-21, Maness Winter 2014 회원
CPSU-MANESS-W14S6G21
4 회원들
안내서 40개 작성하였습니다
댓글 32개
Where can i get the USB charger part from? mine is damaged so the lightbar and charger doesnt work but it will still connect to my PS4 until the battery runs out.
Matthew - 답글
Did you get it repaired? I need help with mine
Ken Wood -
Where can you get a new DualShock 4 Charging Port Replacement?
Tony - 답글
Have you found them?
jee -
Looking for a new charging port .?
Scott Ruskay - 답글
댓글 쓰기
조회 통계:
24 시간 전: 40
7일 전: 235
30일 전: 1,296
전체 시간: 326,988
