주요 콘텐츠로 건너뛰기
Ducky x Varmilo MIYA Pro Panda Keycaps Replacement
필요한 것
  1. Ducky x Varmilo MIYA Pro Panda Keycaps Replacement, Keycaps: 1 단계, 이미지 1/1
    • Take a picture of the layout of your keyboard to remember where each keycap is located for reassembly.
  2. Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 2 단계, 이미지 1/3 Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 2 단계, 이미지 2/3 Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 2 단계, 이미지 3/3
    • Turn the keyboard off.
    • Unplug the USB-C cable connecting the computer to the keyboard.
  3. Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 3 단계, 이미지 1/3 Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 3 단계, 이미지 2/3 Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 3 단계, 이미지 3/3
    • Place the two latches on the keycap puller under each side of the keycap.
    • Pull vertically up to remove the keycap.
    • Only pull vertically up when removing any keycap as any other direction will damage your keyboard.
    • Continue to remove the rest of the keys on the top row of the keyboard.
    • For bigger keycaps such as a spacebar, place one finger under each side of the spacebar to remove it.
  4. Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 4 단계, 이미지 1/3 Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 4 단계, 이미지 2/3 Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 4 단계, 이미지 3/3
    • Dampen a cotton swab with water and run it between each key to pick up any debris.
    • Make sure the cotton swab is damp, not soaking, as too much water may damage the keyboard.
  5. Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 5 단계, 이미지 1/2 Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 5 단계, 이미지 2/2
    • Repeat Steps 3 and 4 until all keycaps are removed and the debris in between the keys has been cleaned.
  6. Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 6 단계, 이미지 1/2 Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 6 단계, 이미지 2/2
    • If you have replacement keycaps, skip to Step 9.
    • If you are reusing your current keycaps, proceed to the next step.
  7. Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 7 단계, 이미지 1/3 Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 7 단계, 이미지 2/3 Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 7 단계, 이미지 3/3
    • Submerge all the keycaps in a bowl of room temperature water.
    • Add a few drops of dish detergent and mix the solution around.
    • Let the keycaps soak in the water solution for 10-15 minutes.
  8. Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 8 단계, 이미지 1/3 Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 8 단계, 이미지 2/3 Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 8 단계, 이미지 3/3
    • Remove the keycaps from the water solution and place them on a towel.
    • Scrub each keycap gently with a dry towel until each keycap is dry.
    • Air dry the keycaps for 30 minutes to dry up any excess moisture.
  9. Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 9 단계, 이미지 1/3 Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 9 단계, 이미지 2/3 Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 9 단계, 이미지 3/3
    • Place each keycap in its original position.
    • Push vertically down once the shape under the keycaps align with the placeholder.
    • Do not use too much force as it may damage your keyboard and the keycap.
    • You should hear a click to signal that your keycap has been placed correctly.
    • Be sure to reference the picture you took at Step 1 to place each keycap in its correct position.
  10. Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 10 단계, 이미지 1/3 Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 10 단계, 이미지 2/3 Ducky x Varmilo MIYA Pro Panda Keycaps Replacement: 10 단계, 이미지 3/3
    • Repeat Step 9 until all keycaps are in their correct positions.
결론
Refer to step 10 to reassemble your keyboard. After following all the steps in this repair guide your keyboard should feel brand new and the responsiveness of your keys should be faster than ever.
Justin Huynh
회원 가입일: 01/17/22
230 평판
안내서 1개 작성함
York University, Team S-10, Woodhouse Winter 2022 York University, Team S-10, Woodhouse Winter 2022 회원
YORK-WOODHOUSE-W22SSG10
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 46
전체 시간: 1,447
