주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Durofix RV332 Battery Replacement
필요한 것
  1. Durofix RV332 Battery Replacement, Battery: 1 단계, 이미지 1/3 Durofix RV332 Battery Replacement, Battery: 1 단계, 이미지 2/3 Durofix RV332 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Remove the six 13mm case screws with a #0 phillips screwdriver.
    • Separate the screwdriver housing with a plastic opening tool.
    • Remove battery casing half to expose screwdriver internals.
  2. Durofix RV332 Battery Replacement: 2 단계, 이미지 1/2 Durofix RV332 Battery Replacement: 2 단계, 이미지 2/2
    • Locate battery
    • Remove battery, printed circuit board, LED, and motor assembly from screwdriver casing.
  3. Durofix RV332 Battery Replacement: 3 단계, 이미지 1/1
    • Using side cutters, cut the red and black wires connecting the battery to the printed circuit board just after the shrink wrap tubing.
    • Strip the ends of the wires attached to the printed circuit board 1/4 inch above the ends of the cut wires.
    • Solder the new battery to the stripped wires attached to the printed circuit board.
    • Wrap the newly soldered connections with electrical tape.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Brennan Wade
회원 가입일: 02/21/14
122 평판
안내서 1개 작성함
Michigan Tech, Team 5-5, Lauer Spring 2014 Michigan Tech, Team 5-5, Lauer Spring 2014 회원
MTU-LAUER-S14S5G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 2,631
