주요 콘텐츠로 건너뛰기
Durofix RV332 Motor Replacement
필요한 것
  1. Durofix RV332 Motor Replacement, Screwdriver Motor: 1 단계, 이미지 1/1
    • Remove the six 13 mm case screws with philips #0 screwdriver.
  2. Durofix RV332 Motor Replacement: 2 단계, 이미지 1/2 Durofix RV332 Motor Replacement: 2 단계, 이미지 2/2
    • Use the plastic separating tool to separate the casing halves of the cordless screwdriver.
  3. Durofix RV332 Motor Replacement: 3 단계, 이미지 1/2 Durofix RV332 Motor Replacement: 3 단계, 이미지 2/2
    • Once the screwdriver casings have been separated, remove the printed circuit board, battery, LED, and motor assembly from the screwdriver casing.
    • Using the wire cutters, cut the black and red motor wires where they connect to the motor.
  4. Durofix RV332 Motor Replacement: 4 단계, 이미지 1/1
    • Strip the ends of the wires clean with the wire cutters. Strip the wire insulation 1/4" from the end of the wire.
  5. Durofix RV332 Motor Replacement: 5 단계, 이미지 1/3 Durofix RV332 Motor Replacement: 5 단계, 이미지 2/3 Durofix RV332 Motor Replacement: 5 단계, 이미지 3/3
    • Ensure the new motor terminals are clean before soldering.
    • Solder the red wire to the positive motor terminal, designated by a plus sign with a red circle around it.
    • Solder the black wire to the other terminal of the motor.
    • Allow the newly soldered assembly to cool before continuing.
  6. Durofix RV332 Motor Replacement: 6 단계, 이미지 1/1
    • Once the motor has cooled, replace the motor, printed circuit board, LED, and battery inside the screwdriver casing.
결론
Tyler Vincent
회원 가입일: 02/24/14
464 평판
안내서 4개 작성하였습니다
Michigan Tech, Team 5-5, Lauer Spring 2014 Michigan Tech, Team 5-5, Lauer Spring 2014 회원
MTU-LAUER-S14S5G5
3 회원들
안내서 5개 작성하였습니다
One Comment
Too late finding this (although self-explanatory). I was wondering when I tried this - WHERE does one find the spare component motor to replace? I searched the internet, but for something so specific, I just couldn't locate the right channels. For future reference, is there a typical store of small motors, etc... to locate these things?
Arkadiusz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 701
