주요 콘텐츠로 건너뛰기
Dymo LabelManager 160 Wheelhead Replacement
필요한 것
  1. Dymo LabelManager 160 Wheelhead Replacement, Batteries: 1 단계, 이미지 1/1
    • Place the device face-down to access the battery compartment.
  2. Dymo LabelManager 160 Wheelhead Replacement: 2 단계, 이미지 1/1
    • Remove the compartment cover to reveal the batteries. Remove the 6 old batteries.
  3. Dymo LabelManager 160 Wheelhead Replacement, Keyboard: 3 단계, 이미지 1/1
    • To open the cartridge compartment, simply lift on the front of the device.
  4. Dymo LabelManager 160 Wheelhead Replacement: 4 단계, 이미지 1/2 Dymo LabelManager 160 Wheelhead Replacement: 4 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove the four 1.3mm screws from the cartridge compartment and two 1.2mm screws from the battery compartment.
  5. Dymo LabelManager 160 Wheelhead Replacement: 5 단계, 이미지 1/1
    • Using a spudger or other tool, lift and remove the front of the device. This should be done all around the device to ensure the two parts split correctly.
  6. Dymo LabelManager 160 Wheelhead Replacement: 6 단계, 이미지 1/3 Dymo LabelManager 160 Wheelhead Replacement: 6 단계, 이미지 2/3 Dymo LabelManager 160 Wheelhead Replacement: 6 단계, 이미지 3/3
    • Gently remove the rubber keyboard from the device.
  7. Dymo LabelManager 160 Wheelhead Replacement, Wheelhead: 7 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, remove the three 1.1 mm screws from the circuit board.
  8. Dymo LabelManager 160 Wheelhead Replacement: 8 단계, 이미지 1/1
    • Lifting the circuit board, use a Phillips #1 screwdriver to remove the two 1.2mm screws from under the circuit board.
  9. Dymo LabelManager 160 Wheelhead Replacement: 9 단계, 이미지 1/2 Dymo LabelManager 160 Wheelhead Replacement: 9 단계, 이미지 2/2
    • Proceed to lift the excess device components until the rollerblade is visible.
  10. Dymo LabelManager 160 Wheelhead Replacement: 10 단계, 이미지 1/1
    • With the device components exposed, gently lift the wheelhead out of the label maker.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Matthew Jenkins
회원 가입일: 01/27/16
259 평판
안내서 2개 작성하였습니다
University of Alabama, Team 1-4, Sydow campbell Spring 2016 University of Alabama, Team 1-4, Sydow campbell Spring 2016 회원
UA-SYDOW CAMPBELL-S16S1G4
4 회원들
안내서 4개 작성하였습니다
댓글 3개
Group 9: Over all looks great. Pictures are great quality and hand placement in pictures. The circles and arrows should all be red. The only time the color changes is if there are different steps within a single picture.
Zachary Parker - 답글
thank you for the procedure, i mis one screen in the procedure how to detach display?
aslan - 답글
Guide does not properly address or account for parts that will simply fall out if you proceed with this course. Gears, springs, plastic bits, metal rods. I had a pile of seven or eight unknown bits, plus the plastic gears.
No photos of the gearing, or the levers that hold tension on the label ribbon. These are the parts will fall out.
All I’ve managed to do is take apart and reassemble, only to have pieces that are now out, who knows where they go. Device now gives me a label jam error when reassembled. Have no clue how the tensioner should be oriented.
Gonna move on and buy a new label maker now. Thanks for the frustration ifixit.
Christopher Warren - 답글
댓글 쓰기
조회 통계:
24 시간 전: 16
7일 전: 23
30일 전: 73
전체 시간: 4,243
