주요 콘텐츠로 건너뛰기
Dymo LabelManager 280 Rear Case Replacement
필요한 것
  1. Dymo LabelManager 280 Rear Case Replacement, Rear Case: 1 단계, 이미지 1/2 Dymo LabelManager 280 Rear Case Replacement, Rear Case: 1 단계, 이미지 2/2
    • Remove battery.
    • Remove the label cassette.
  2. Dymo LabelManager 280 Rear Case Replacement: 2 단계, 이미지 1/2 Dymo LabelManager 280 Rear Case Replacement: 2 단계, 이미지 2/2
    • Remove the 6 screws in the indicated places. These particular screws are 2mm x 8mm Phillips #0 head
  3. Dymo LabelManager 280 Rear Case Replacement: 3 단계, 이미지 1/2 Dymo LabelManager 280 Rear Case Replacement: 3 단계, 이미지 2/2
    • Use the spudger to take apart the device by insterting it as shown in the picture and twisting it. This should be done all around the device to ensure the two parts split correctly.
    • The keys/buttons highlighted in the second picture fall out easily so be careful. Keep device faced down in order to keep them from falling.
결론
Steven Nguyen
회원 가입일: 02/08/16
431 평판
안내서 3개 작성하였습니다
USF Tampa, Team 6-5, Eyestone Spring 2016 USF Tampa, Team 6-5, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S6G5
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 26
전체 시간: 589
