주요 콘텐츠로 건너뛰기
Dynex DX-WBRDVD1 Cleaning The Optical Lens
필요한 것
  1. Dynex DX-WBRDVD1 Cleaning The Optical Lens, Top Cover: 1 단계, 이미지 1/2 Dynex DX-WBRDVD1 Cleaning The Optical Lens, Top Cover: 1 단계, 이미지 2/2
    • Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
  2. Dynex DX-WBRDVD1 Cleaning The Optical Lens: 2 단계, 이미지 1/1
    • Remove the two 5mm screws on the left and right side panels.
    • There is one screw on each side that secures the cover to the body of the device.
  3. Dynex DX-WBRDVD1 Cleaning The Optical Lens: 3 단계, 이미지 1/1
    • Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
    • Check that the power cord is not preventing the device from opening or closing.
  4. Dynex DX-WBRDVD1 Cleaning The Optical Lens, Dynex DX-WBRDVD1 Cleaning The Optical Lens: 4 단계, 이미지 1/2 Dynex DX-WBRDVD1 Cleaning The Optical Lens, Dynex DX-WBRDVD1 Cleaning The Optical Lens: 4 단계, 이미지 2/2
    • To access the optical lens, pull back the optical drive as shown in the pictures located on the two metal rails.
  5. Dynex DX-WBRDVD1 Cleaning The Optical Lens: 5 단계, 이미지 1/2 Dynex DX-WBRDVD1 Cleaning The Optical Lens: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    구매
결론
다른 3명이 해당 안내서를 완성하였습니다.
Caleigh Firth
회원 가입일: 04/05/18
438 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 587
