소개
The discdrive is found next to the motherboard and power board inside the device. This guide will take you through the steps of removing the discdrive for replacement.
필요한 것
Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
Use a Phillips #1 screwdriver to remove the two screws that secure the Optical Drive.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
