주요 콘텐츠로 건너뛰기
Dynex DX-WBRDVD1 Power Supply Board Replacement
필요한 것
  1. Dynex DX-WBRDVD1 Power Supply Board Replacement, Top Cover: 1 단계, 이미지 1/2 Dynex DX-WBRDVD1 Power Supply Board Replacement, Top Cover: 1 단계, 이미지 2/2
    • Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
  2. Dynex DX-WBRDVD1 Power Supply Board Replacement: 2 단계, 이미지 1/1
    • Remove the two 5mm screws on the left and right side panels.
    • There is one screw on each side that secures the cover to the body of the device.
  3. Dynex DX-WBRDVD1 Power Supply Board Replacement: 3 단계, 이미지 1/1
    • Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
    • Check that the power cord is not preventing the device from opening or closing.
  4. Dynex DX-WBRDVD1 Power Supply Board Replacement, Power Supply Board: 4 단계, 이미지 1/2 Dynex DX-WBRDVD1 Power Supply Board Replacement, Power Supply Board: 4 단계, 이미지 2/2
    • Remove the 9-pin white wire from the power board (brown) that connects to the motherboard (green).
  5. Dynex DX-WBRDVD1 Power Supply Board Replacement: 5 단계, 이미지 1/2 Dynex DX-WBRDVD1 Power Supply Board Replacement: 5 단계, 이미지 2/2
    • Remove the front plate of the device by removing the top two screws on either side and pulling the plate away.
    • Make sure to place the grounding wire between the screw and the device when reassembling.
  6. Dynex DX-WBRDVD1 Power Supply Board Replacement: 6 단계, 이미지 1/2 Dynex DX-WBRDVD1 Power Supply Board Replacement: 6 단계, 이미지 2/2
    • Remove the 4 screws holding the power board to the body of the device.
    • Remember to connect a grounding wire to the screw next to the front panel and optical drive when reassembling.
  7. Dynex DX-WBRDVD1 Power Supply Board Replacement: 7 단계, 이미지 1/2 Dynex DX-WBRDVD1 Power Supply Board Replacement: 7 단계, 이미지 2/2
    • Press down on the plastic flap to unlatch the white clip on the edge of the power supply board.
  8. Dynex DX-WBRDVD1 Power Supply Board Replacement: 8 단계, 이미지 1/1
    • Remove the power supply board.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Caleigh Firth
회원 가입일: 04/05/18
438 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 17
전체 시간: 713
