주요 콘텐츠로 건너뛰기
동영상 개요
해당 분해도는 수리 안내서가 아닙니다. Dyson AM10 Humidifier 수리는 자사의 서비스 설명서를 사용하세요.
  1. Dyson AM10 Humidifier Tear-Down, Clean, Repair, Clean the tank, lots of brush positioning: 1 단계, 이미지 3개 중 1개 Dyson AM10 Humidifier Tear-Down, Clean, Repair, Clean the tank, lots of brush positioning: 1 단계, 이미지 3개 중 2개 Dyson AM10 Humidifier Tear-Down, Clean, Repair, Clean the tank, lots of brush positioning: 1 단계, 이미지 3개 중 3개
    • Use these brushes from AliExpress to clean the tank insides. Each one provides a slightly different position. Together they cost about $7 and can be used for other hard-to-reach places. The tank has a few unreachable places which are in the last 2 images. I cleaned >95% of the moss.
  2. Dyson AM10 Humidifier Tear-Down, Clean, Repair, Open the fan, wash it out: 2 단계, 이미지 3개 중 1개 Dyson AM10 Humidifier Tear-Down, Clean, Repair, Open the fan, wash it out: 2 단계, 이미지 3개 중 2개 Dyson AM10 Humidifier Tear-Down, Clean, Repair, Open the fan, wash it out: 2 단계, 이미지 3개 중 3개
    • Need torx (star-shaped) screwdriver (8 & 10). BE CAREFUL with screws, because they are anchored in the plastic!! Too far and you crack it, so use your hands and move slowly. A few tools to get: Magnetizer to hold torx screws, Lastly, image 1 shows me sliding the top forward into the tabs - move slowly because it feels fragile.
  3. Dyson AM10 Humidifier Tear-Down, Clean, Repair, Fan apart View: 3 단계, 이미지 3개 중 1개 Dyson AM10 Humidifier Tear-Down, Clean, Repair, Fan apart View: 3 단계, 이미지 3개 중 2개 Dyson AM10 Humidifier Tear-Down, Clean, Repair, Fan apart View: 3 단계, 이미지 3개 중 3개
    • I rinsed it with water There are 3 levels of screws to take out: The white outside cover, this black capsule in frame #2 and the rotor in my hand (image #3).
  4. Dyson AM10 Humidifier Tear-Down, Clean, Repair, The head: 4 단계, 이미지 3개 중 1개 Dyson AM10 Humidifier Tear-Down, Clean, Repair, The head: 4 단계, 이미지 3개 중 2개 Dyson AM10 Humidifier Tear-Down, Clean, Repair, The head: 4 단계, 이미지 3개 중 3개
    • In image 1 I'm pressing the white outside with my thumb while digging fingernails in this crack and pulling up carefully. Work your way around slowly and the rim comes off. I have no idea how to get the rest apart and I don't think you need it.
  5. Dyson AM10 Humidifier Tear-Down, Clean, Repair, The Atomizer: 5 단계, 이미지 2개 중 1개 Dyson AM10 Humidifier Tear-Down, Clean, Repair, The Atomizer: 5 단계, 이미지 2개 중 2개
    • The atomizer or nebulizer is the core feature which creates the mist. In the main photo, it is clearly electrified and ultrasonically vibrates and breaks up (nebulizes) the water into the mist. The 'charged' disc underside has 3 'rings': the shiny anode and cathode (positive and negative) separated by a non-conducting dark ceramic ring.
  6. Dyson AM10 Humidifier Tear-Down, Clean, Repair, Replacing the Piezo Atomizer: 6 단계, 이미지 1개 중 1개
    • Ideally, someone will contribute a link to a vender for these atomizer discs which truly cost about $0.25 each. Sadly, on Amazon there are $47 repair kits. I would be willing to buy 100 for $25, contact me. This top of this TDK disc has damage from normal use. Note the shiny conductive top layer over the ceramic showing through from underneath.
작성자
2다른 기여자 명과 함께
Paul Tast
회원 가입일: 09/17/16
984 평판
안내서 7개를 작성함
2가이드 댓글
Nowadays it seems difficult to find the brushes. Do you have a tag or link towards those? Maybe even on another platform?
Oliver Hinz - 답글
I bought these and other things on AliExpress.
Paul Tast - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 24
지난 30일: 154
전체 시간: 5,158
