주요 콘텐츠로 건너뛰기
Dyson Ball Animal Power Button Replacement
필요한 것
  1. Dyson Ball Animal Power Button Replacement, Power Button: 1 단계, 이미지 1/2 Dyson Ball Animal Power Button Replacement, Power Button: 1 단계, 이미지 2/2
    • Turn off and unplug the vacuum
  2. Dyson Ball Animal Power Button Replacement: 2 단계, 이미지 1/1
    • Press the red release button and pull the canister up and away.
  3. Dyson Ball Animal Power Button Replacement: 3 단계, 이미지 1/2 Dyson Ball Animal Power Button Replacement: 3 단계, 이미지 2/2
    • Locate the red dial at the back of the wand and turn counterclockwise to detach the wand.
  4. Dyson Ball Animal Power Button Replacement: 4 단계, 이미지 1/2 Dyson Ball Animal Power Button Replacement: 4 단계, 이미지 2/2
    • Remove the four 15mm screws behind the power button using a Torx T15 screwdriver.
  5. Dyson Ball Animal Power Button Replacement: 5 단계, 이미지 1/3 Dyson Ball Animal Power Button Replacement: 5 단계, 이미지 2/3 Dyson Ball Animal Power Button Replacement: 5 단계, 이미지 3/3
    • Use a spudger to push the two clamp tabs behind the power button towards the middle of the vacuum.
  6. Dyson Ball Animal Power Button Replacement: 6 단계, 이미지 1/2 Dyson Ball Animal Power Button Replacement: 6 단계, 이미지 2/2
    • Detach the power box case from the body of the Dyson after both clamps have been pushed out.
    • Upon removal of this case, you will be able to see a red circular power button.
  7. Dyson Ball Animal Power Button Replacement: 7 단계, 이미지 1/2 Dyson Ball Animal Power Button Replacement: 7 단계, 이미지 2/2
    • Gently pull the power button out of its slot as shown.
    • Detach the power button box from the two wires connecting it, and replace the faulty power button box with a functional one. The power button is the first black one.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Hank Wai
회원 가입일: 05/07/17
166 평판
안내서 1개 작성함
Cal Poly, Team S15-G5, Banghart Spring 2017 Cal Poly, Team S15-G5, Banghart Spring 2017 회원
CPSU-BANGHART-S17S15G5
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 11
30일 전: 50
전체 시간: 6,792
