주요 콘텐츠로 건너뛰기
Dyson Ball Animal Power Cord Replacement
필요한 것
  1. Dyson Ball Animal Power Cord Replacement, Power Cord: 1 단계, 이미지 1/1
    • Turn off and unplug the vacuum.
    • Remove the vacuum canister from the front of the vacuum.
  2. Dyson Ball Animal Power Cord Replacement: 2 단계, 이미지 1/1
    • Flip the vacuum around and remove the hose so it is not blocking the back of the vacuum.
  3. Dyson Ball Animal Power Cord Replacement: 3 단계, 이미지 1/3 Dyson Ball Animal Power Cord Replacement: 3 단계, 이미지 2/3 Dyson Ball Animal Power Cord Replacement: 3 단계, 이미지 3/3
    • There are four 15mm screws that must be removed with a Torx T15 screwdriver.
  4. Dyson Ball Animal Power Cord Replacement: 4 단계, 이미지 1/3 Dyson Ball Animal Power Cord Replacement: 4 단계, 이미지 2/3 Dyson Ball Animal Power Cord Replacement: 4 단계, 이미지 3/3
    • After all the screws are released there are two tabs that must be pressed in and towards the center.
    • The tabs can be pressed in one at a time but may require some force.
  5. Dyson Ball Animal Power Cord Replacement: 5 단계, 이미지 1/2 Dyson Ball Animal Power Cord Replacement: 5 단계, 이미지 2/2
    • After removing the two tabs gently pull the face off the power supply.
  6. Dyson Ball Animal Power Cord Replacement: 6 단계, 이미지 1/1
    • Follow the black cord from the power cord.
    • Pinch the plastic piece.
    • Remove from the metal tongue.
    • When removing the cords, grab them from the plastic parts and not the cord.
  7. Dyson Ball Animal Power Cord Replacement: 7 단계, 이미지 1/3 Dyson Ball Animal Power Cord Replacement: 7 단계, 이미지 2/3 Dyson Ball Animal Power Cord Replacement: 7 단계, 이미지 3/3
    • There is also a black case that needs to be opened in order to remove the power cord.
    • After opening the case pull apart the wire and attach the new wire.
    • Again, make sure that you are pulling from the heads of the wires and not the wires themselves.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jonathan Gong-Guy
회원 가입일: 04/17/17
314 평판
안내서 1개 작성함
Cal Poly, Team S15-G5, Banghart Spring 2017 Cal Poly, Team S15-G5, Banghart Spring 2017 회원
CPSU-BANGHART-S17S15G5
4 회원들
안내서 16개 작성하였습니다
댓글 3개
Great tutorial! The pictures were awesome, I replaced my cord in about 15 minutes thanks to this post. The only thing you might want to add is the gray switch with the spring. Mine fell out while I was trying to put the unit back together and I had to research how it went back together correctly. Thanks again!
Jim
Jim Knox - 답글
I had the same spring lever issue. This video shows how to replace them.
https://youtu.be/CLk1Zu6nREk
Robert W Marvin - 답글
Thank you for the YouTube link on the button reassembly. I should have expected it to be sitting loaded when I disassembled it.
chuckparent -
댓글 쓰기
조회 통계:
24 시간 전: 13
7일 전: 65
30일 전: 335
전체 시간: 33,073
