주요 콘텐츠로 건너뛰기
Dyson Ball Multi Floor Upright Electrical Cord Replacement
필요한 것
  1. Dyson Ball Multi Floor Upright Electrical Cord Replacement, Electrical Cord: 1 단계, 이미지 1/2 Dyson Ball Multi Floor Upright Electrical Cord Replacement, Electrical Cord: 1 단계, 이미지 2/2
    • Press the red button on the back to release the hose and allow for easy access to the back
  2. Dyson Ball Multi Floor Upright Electrical Cord Replacement: 2 단계, 이미지 1/1
    • Remove the four 15 mm T-10 black screws now showing in the back of the vacuum hose track, using the Phillips 0 screwdriver found in the iFixit tool kit.
  3. Dyson Ball Multi Floor Upright Electrical Cord Replacement: 3 단계, 이미지 1/2 Dyson Ball Multi Floor Upright Electrical Cord Replacement: 3 단계, 이미지 2/2
    • Use a pair of needle nosed pliers to press both tabs simultaneously.
    • Hold onto the front hatch while doing this or it will fall off and a spring and lever will fall out with it.
    • Remove the hatch carefully exposing the wiring underneath
  4. Dyson Ball Multi Floor Upright Electrical Cord Replacement: 4 단계, 이미지 1/2 Dyson Ball Multi Floor Upright Electrical Cord Replacement: 4 단계, 이미지 2/2
    • Remove the black wire from its connection near the top of the hatch
  5. Dyson Ball Multi Floor Upright Electrical Cord Replacement: 5 단계, 이미지 1/2 Dyson Ball Multi Floor Upright Electrical Cord Replacement: 5 단계, 이미지 2/2
    • Open the black box near the bottom of the hatch area using the two push tabs
    • This exposes the white wire's connection
  6. Dyson Ball Multi Floor Upright Electrical Cord Replacement: 6 단계, 이미지 1/1
    • Disconnect the white wire using the small metal tab.
    • Do not damage the wire during the process.
  7. Dyson Ball Multi Floor Upright Electrical Cord Replacement: 7 단계, 이미지 1/1
    • Pull vertically on the grey cord now and it should separate from the rest of the vacuum
    • To replace the cord, slide the new grey cord into place and connect the two wires again then complete the steps in reverse
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nicole Abraham
회원 가입일: 01/26/17
839 평판
안내서 5개 작성하였습니다
Cal Poly, Team 21-2, Maness Winter 2017 Cal Poly, Team 21-2, Maness Winter 2017 회원
CPSU-MANESS-W17S21G2
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
Supposing that one doesn't hold onto the front part, and the spring and lever fall out, how does one replace said spring and lever?
Jordan Adams - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 45
전체 시간: 3,746
