소개
If you are using your Dyson Multi Floor Upright and there are problems or damages to the electrical cord that are causing issues with the power of your vacuum, the problem is most likely the electrical cord. The best solution to this problem is to replace the electrical cord.
필요한 것
Press the red button on the back to release the hose and allow for easy access to the back
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Supposing that one doesn't hold onto the front part, and the spring and lever fall out, how does one replace said spring and lever?
