주요 콘텐츠로 건너뛰기
Dyson Ball Multi Floor Upright Main Filter Replacement
필요한 것
  1. Dyson Ball Multi Floor Upright Main Filter  Replacement, Main Filter: 1 단계, 이미지 1/3 Dyson Ball Multi Floor Upright Main Filter  Replacement, Main Filter: 1 단계, 이미지 2/3 Dyson Ball Multi Floor Upright Main Filter  Replacement, Main Filter: 1 단계, 이미지 3/3
    • For the main filter, locate the body of the vacuum by looking for the cylinder with the orange top. Use your thumb to press down on the red button towards the back of the orange piece.
    • After pressing down on the red button, the body of the vacuum will easily be removed from the vacuum stand.
  2. Dyson Ball Multi Floor Upright Main Filter  Replacement: 2 단계, 이미지 1/3 Dyson Ball Multi Floor Upright Main Filter  Replacement: 2 단계, 이미지 2/3 Dyson Ball Multi Floor Upright Main Filter  Replacement: 2 단계, 이미지 3/3
    • Once the main body of the vacuum is removed, locate the clear handle on the top of the body. There is a purple label that says "Filter".
    • Lift up the clear handle to reveal the main cylindrical filter. Pull out the purple filter piece to replace.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Nicole Abraham
회원 가입일: 01/26/17
839 평판
안내서 5개 작성하였습니다
Cal Poly, Team 21-2, Maness Winter 2017 Cal Poly, Team 21-2, Maness Winter 2017 회원
CPSU-MANESS-W17S21G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 35
전체 시간: 3,572
