소개
If your Dyson Multi Floor Upright is having problems with mobility and constantly causing issues moving from place to place while in use, it is probably time to replace the wheels on your vacuum.
필요한 것
Twist the purple center circle counter clockwise until loose. This will leave the entire grey covering loosened.
Place a pair of small needle-nose pliers in the small gray center of the side hemisphere. Twist counterclockwise and pull the small center piece out.
Reinsert the small needle nose pliers into the center piece that is now exposed. Twist counterclockwise until you can pull the entire hemisphere off.
Remove the four 10 mm T-10 silver screws on the bottom of the ball of the vacuum and the two lower 15mm T-15 silver screws.
Firmly grab the white, three-pronged piece on the left side and pull it off.
Push off the right side of the piece by placing your thumbs where the first two 15 mm T-10 black screws originally were.
Remove the bottom piece.
Remove the 15 mm T-10 black screw that is located where the wires enter into the vacuum using a Phillips 0 screwdriver.
Press into the notches on either side of the vacuum by using your thumbs. Do this for both sides of the vacuum.
Pull off the protective covering of the circuit board in order to reveal the circuit board.
다른 5명이 해당 안내서를 완성하였습니다.
