주요 콘텐츠로 건너뛰기
Dyson Cinetic Animal Ball Motor Replacement
필요한 것
  1. Dyson Cinetic Animal Ball Motor Replacement, Release the canister: 1 단계, 이미지 1/1
    • Press the gray button to release the canister.
  2. Dyson Cinetic Animal Ball Motor Replacement, Remove the canister: 2 단계, 이미지 1/1
    • Remove the canister by lifting it out.
  3. Dyson Cinetic Animal Ball Motor Replacement, Unscrew the base plate: 3 단계, 이미지 1/1
    • Find and remove the four 21.5mm screws on the bottom that hold the base plate on using a T15 Torx bit.
  4. Dyson Cinetic Animal Ball Motor Replacement: 4 단계, 이미지 1/1
    • Locate and remove the 21mm screws for each wheel on the ball using a T15 Torx bit.
    • Remove the plastic disc.
  5. Dyson Cinetic Animal Ball Motor Replacement, Unscrew the plastic enclosure: 5 단계, 이미지 1/1
    • Locate and remove the five 22mm screws on each side of the ball that keep the plastic enclosure together using a T15 Torx bit.
  6. Dyson Cinetic Animal Ball Motor Replacement, Open up the plastic sphere: 6 단계, 이미지 1/1
    • Remove the bottom half of the plastic sphere to reveal the motor.
  7. Dyson Cinetic Animal Ball Motor Replacement, Remove the motor: 7 단계, 이미지 1/2 Dyson Cinetic Animal Ball Motor Replacement, Remove the motor: 7 단계, 이미지 2/2
    • Carefully slide the motor out of its housing in the ball.
    • Cut the two wires near the side of the motor using wire cutters.
    • Install the new motor by splicing in the wires.
    • Watch this video by NJprepper321 on how to splice together wires if you are unsure on how to do this.
    • Make sure to match the wires on the motor with the correct wires in the vacuum.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Alexandria Pompeii
회원 가입일: 01/25/17
400 평판
안내서 3개 작성하였습니다
Cal Poly, Team 9-5, Banghart Winter 2017 Cal Poly, Team 9-5, Banghart Winter 2017 회원
CPSU-BANGHART-W17S9G5
3 회원들
안내서 18개 작성하였습니다
댓글 4개
Basic but correct only mine has spade connectors on the motor so no need to cut and solder wires. The problem I found was that the main inner filter was blocked, probably by cement dust who I am guilty of! I would like to know if this is available as a spare part? I have cleaned it for now but it really needs changing.
Tim - 답글
This vacuum cleaner is based on the DC52 model. The post motor HEPA filter has the part number 922444-02 and is offered by many spart part vendors in the web. Just google Dyson 922444-02. I have made an instruction on how to replare or clean it.
HowThingsWork -
very good instructions, dismantled perfectly.
Allain Ouellette - 답글
great instructions, dismantled perfectly.
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 45
30일 전: 238
전체 시간: 22,206
